440 six pack - what valley pan tray do I need #347176
06/14/09 10:27 PM
06/14/09 10:27 PM
Williamsport, PA
Rob440Magnum Offline OP
mopar addict
mopar addict
Williamsport, PA
I will be installing a new 440 six pack on my 70 Challenger and I don't know which valley pan tray to order?
I can order just the valley tray or I can order the valley tray with the 4 gaskets. It also needs to have the holes to allow the heat to cross-over. Which do I need? Does anyone know the correct part number?
Thanks, Rob
Re: 440 six pack - what valley pan tray do I need [Re: Rob440Magnum] #347177
06/14/09 11:12 PM
06/14/09 11:12 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You just use the stock part number pan for that.
I would run the blocked heat riser part but to each his own. The choke will be just fine with it blocked. If it doesn't, just wire it open. My car warms up fast and I have the choke wired and a blocked heat riser.
I want my fair share
Re: 440 six pack - what valley pan tray do I need [Re: Rob440Magnum] #347178
06/14/09 11:20 PM
06/14/09 11:20 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
Thanks, Rob
I want to say felpro 1215
