Re: do i need a pinion snubber on a b-body
[Re: topside]
#347130
06/15/09 03:52 PM
06/15/09 03:52 PM
Posts: 1,624 qc
mxbeep
qc
On a street car I wouldn't think so; but if the rear tires hook up, or you have a 4-speed & beat on it, then maybe. With SS springs, you may not need the snubber. I tried one on my drag car and the car didn't like it; hundred or so runs later, still no shaft/joint issues using no snubber. It's possible to make a snubber that mounts to the car and points down at the pinion area, if you think you need one.
forgot to mention car is a 4 speed, street driven with the ocasionnal pounding
[Re: mxbeep]
#347131
06/15/09 03:56 PM
06/15/09 03:56 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
You will get a lot of spring wrap if it is anything like mine. I took mine off and the rear springs are dying. I'm in the process of getting cal tracs
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
