do i need a pinion snubber on a b-body #347128
06/14/09 09:54 PM
06/14/09 09:54 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
Car is all stock suspension, I want to install a dana 60 that as no mounting pad or hardware for a pinion snubber ( converted truck diff).
any danger of driveshaft or u-joint hitting the floor or other consequences.
thanks
Re: do i need a pinion snubber on a b-body [Re: mxbeep] #347129
06/14/09 11:24 PM
06/14/09 11:24 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
On a street car I wouldn't think so; but if the rear tires hook up, or you have a 4-speed & beat on it, then maybe. With SS springs, you may not need the snubber. I tried one on my drag car and the car didn't like it; hundred or so runs later, still no shaft/joint issues using no snubber.
It's possible to make a snubber that mounts to the car and points down at the pinion area, if you think you need one.
Re: do i need a pinion snubber on a b-body [Re: topside] #347130
06/15/09 03:52 PM
06/15/09 03:52 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
forgot to mention car is a 4 speed, street driven with the ocasionnal pounding
Re: do i need a pinion snubber on a b-body [Re: mxbeep] #347131
06/15/09 03:56 PM
06/15/09 03:56 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
You will get a lot of spring wrap if it is anything like mine. I took mine off and the rear springs are dying. I'm in the process of getting cal tracs
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: do i need a pinion snubber on a b-body [Re: HealthServices] #347132
06/15/09 07:39 PM
06/15/09 07:39 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Good STICK SHIFT super-stock springs are the solution for this. You do NOT need a snubber in a leaf-spring rear suspensions that is set-up correctly.
