800 avs throttle #346303
06/14/09 01:57 AM
06/14/09 01:57 AM
Iowa
P
plumcrazyb Offline OP
P
Iowa
Any pics of how to hook a stock superbees throttle cable to a 800 thunder series carb?
Re: 800 avs throttle [Re: plumcrazyb] #346304
06/14/09 10:07 AM
06/14/09 10:07 AM
AndyF Offline
AndyF  Offline
Depends on the intake manifold and whether or not you have a kickdown linkage. But here is one example using the throttle bracket and throttle return from Mancini Racing.
Re: 800 avs throttle [Re: plumcrazyb] #346305
06/14/09 10:22 AM
06/14/09 10:22 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
With this adapter, it's a snap. Will work 100% perfect with the original manifold and throttle cable bracket.
http://www.summitracing.com/parts/EDL-1481/
If you are running a manifold that more than slightly higher than stock, you can use the carb adapter, but the cable bracket won't fly. Andy's stuff is nice here.
MB
