727 trans leak question #346253
06/14/09 12:45 AM
06/14/09 12:45 AM
Anonymous OP
Anonymous OP
My 64 polara has a bad trans leak. I am pretty sure it is a front seal leak. A few trans shops said it could be a bad bushing in the torque converter. Is this true? I thought the torque converter was sealed up by the front seal of the trans. Thanx guys
Re: 727 trans leak question #346254
06/14/09 01:10 AM
06/14/09 01:10 AM
yes the front pump seal seals the TC & worst case it could be a bad bushing which is behind the seal & the TC snout goes thru the seal then thru the bushing then engages the front pump. I would pull the trans back, take out the TC & R&R the front pump seal & put it back together. odds are you will be fine.
Re: 727 trans leak question [Re: RapidRobert] #346255
06/14/09 02:51 AM
06/14/09 02:51 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Agree with RR ... also .. when you pull that old seal ... you can look at the bushing. If it is loose OR it has damaged the hub of the converter - you should then change the bushing also.
Re: 727 trans leak question [Re: BeEtLeJuIcE !] #346256
06/14/09 08:34 AM
06/14/09 08:34 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Change the bushing while you have it out. And the gasket around the pump. I'd do the shift selector seal too. And the neutral safety switch seal. Had them all leak at one time or another.
Re: 727 trans leak question [Re: bobby66] #346257
06/14/09 09:13 AM
06/14/09 09:13 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
A bad bushing will cuase a new seal to fail pretty quick.
Re: 727 trans leak question [Re: WILD BILL] #346258
06/14/09 11:50 AM
06/14/09 11:50 AM
MO
P
psycho_440 Offline
psycho_440  Offline
P
MO
i had a bad front bushing. it spun and basically trashed the whole tranny very quickly. sent lots of metal everywhere. if i ever have one start leaking fluid from the front it is coming out immediately. my tranny guy said that the bushing holds the fluid in more than the seal so if you have a leak in front its most likely the bushing. the bushing had seized onto the converter. trashed the front pump, planetaries, rear over-running clutch, valvebody, and a drum, oh and of course the converter. better get it looked at
