I have a '71 340 that I rebuilt that is running poorly and has very low vacumn. The block is 30 over, has a mild MP purple shaft, X heads, stock intake and thermoquad. I've checked the cam centerline and compression which are to specs. I've changed carbs, distributor, coil and wires and no improvement. I've checked for vacumn leaks but can't find anything obvious. Timing is advanced 10 degrees at idle. If I advance more than this it won't start.
Any recommendations? If its a vacumn leak, what are some of the likely areas to check?
