Gains from ditching the torsion bars? #345735
06/13/09 02:38 PM
06/13/09 02:38 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
Just wondering about you guys that have replace the torsion bars with coilovers?? Happy or regret??
Re: Gains from ditching the torsion bars? [Re: JandJ_Racing] #345736
06/13/09 03:24 PM
06/13/09 03:24 PM
UK
602heavy Offline
602heavy  Offline
UK
I'd like to know also , doing this on a 68 bee @ the moment.
Re: Gains from ditching the torsion bars? [Re: 602heavy] #345737
06/13/09 06:22 PM
06/13/09 06:22 PM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
Re: Gains from ditching the torsion bars? [Re: JandJ_Racing] #345738
06/13/09 09:46 PM
06/13/09 09:46 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I did it on our Dart and and have mixed feelings about it. Performance wise , I don't think it made much difference, maybe helped the drivability of it @ 130 mph. What I was after is the front end would not settle and was still riding high at the finish line, and that problem is gone. I had koni's, drilled stock shocks and QA1's and it still did it, so I swapped it to Afco coil overs and now it goes through at normal ride height.
Re: Gains from ditching the torsion bars? [Re: JandJ_Racing] #345739
06/13/09 10:06 PM
06/13/09 10:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I did the swap about 15 years ago(last time I had
T-bars), it made about .15 better in the 60' but I
did a couple of things to it then, it did transfer
the weight better.
Re: Gains from ditching the torsion bars? [Re: Lil Wedge] #345740
06/13/09 10:44 PM
06/13/09 10:44 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
we have run both front setups.normally torsion bars sem to push the front up a little quicker and a little higher.but like what was stated it also holds the front up more downtrack hurting driveabilty.the biggest gain from coilovers is header clearance.you have better driveabilty with coilovers and more adjustabilty.it is hard to get a coilover long enough on the front of a mopar to get the travel that you have with a torsionbar setup.one of the best things you can do on a mopar front is to use a strutrod with the heimends like bill reily sells.they free up the front of the car and make it much better to handle
Re: Gains from ditching the torsion bars? [Re: webemopes] #345741
06/14/09 06:53 AM
06/14/09 06:53 AM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I agree with that, I bought the strut rods same time as the coil overs from Rielly and now it stages like a dragster, no flex or movement, really helps when bumping in.
