727 and 904 transmissions #345541
06/13/09 01:03 AM
06/13/09 01:03 AM
Ohio
LABBINSKI Offline OP
Ohio
Do these transmissions share the same torque specs for the front and rear band adjustments thanks Brian
Re: 727 and 904 transmissions [Re: LABBINSKI] #345542
06/13/09 02:23 AM
06/13/09 02:23 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
The torque specs are not the same for these transmissions. The only thing they share is that you run them into 72inch pounds and then back them off their rec'd turns. Sorry I do not know the turns for each, but I know they are different.
Re: 727 and 904 transmissions [Re: wheelsup68dart] #345543
06/14/09 10:12 AM
06/14/09 10:12 AM
scratchnfotraction Offline
carl monroes book is a good read on the torqueflight trannys
it goes by the ratio stamped on the lever that works the band...3.8-4.2 5.0...ect
and set acordinly...
with the ratio "unknowen" it said to run it in to 72 inch/lbs and back off 2 1/2 turns
good luck with it
