Re: CalTracks on the street
[Re: 11secondC]
#345399
06/12/09 11:04 PM
06/12/09 11:04 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Without the Rancho's or something similiar your missing 1/3 of the equation imo...mine would verge on wheelhop/porpoise with the stock shocks on there...forgot to add I've been running mine on the street now for 6 yrs now...just as I set em up for the strip...
DITTO, but i gotcha by one year
[Re: Dartman75]
#345403
06/14/09 12:06 PM
06/14/09 12:06 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I run my shocks on 7 and the bars are set with 1/4 turn preload on right and snugged up on left with me in the car.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Dartman75]
#345404
06/14/09 08:01 PM
06/14/09 08:01 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have to set my Ranchos to 9 at the track for hard launches or I will get bad shudder on launch. But the ride is just too jarring on the street with the higher settings, so I have the shocks set on 1 for the street.
Master, again and still
[Re: kingdust]
#345406
06/15/09 09:52 AM
06/15/09 09:52 AM
Posts: 233 Amarillo, Tx
daithi2
Amarillo, Tx
my caltracs hook much better with a soft setting on the shocks.
47 Dodge - turbocharged 493"
05 SRT6 - Only 10 second and fastest SRT-6
[Re: kingdust]
#345409
06/15/09 01:39 PM
06/15/09 01:39 PM
Posts: 3,078 Edmonton, Alberta, Canada
Dartman75
I see a part number that appears to be teh correct shock for the front, which is great: http://www.summitracing.com/parts/HAL-RC1538P/Edit: Found the rest of the shocks on summit's site by going to QA-1's site and looking up prt numbers. I see they are expensive shocks, especially the double adjustables. I don't think I want a firm compression for the street, so I'd prefer double adjustable. Especially with the really high rate torsions I run, it's likely I need a medium to firm compression and the ability to change the rebound soft for the strip (front end rise) and very firm for the street. Are the equivalent adjustables out there or am I pretty much limited to Qa1 for a double adjustable shock? Greg
[Re: Dartman75]
#345410
06/15/09 04:04 PM
06/15/09 04:04 PM
Posts: 189 long island new york
kingdust
Out of all the double adj.shocks the QA1s are probably the cheapest. Don't get me wrong, the rancho,s work,but in my case I had to put a brace on my 8/34 and the shocks (being in the stock location) would hit the brace when I launched the car.I've since went to a 9" and still had to notch the brace for shock clearance,but I have no clearance issues now with the QA1s good luck. Mark
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: Dartman75]
#345412
06/17/09 09:53 PM
06/17/09 09:53 PM
I use the QA1 Stocker Star R on the front of my Dakota. Single adjustable, 12 way. Position 1 is like a 90/10 and works great at the track....a little bouncy on the street. If I drive more than 20 miles or so to a track I'll set the shocks at position 6 and get a very comfortable, well controlled ride and decent handling. Just my
