Need picture of front of damper installed #345175
06/12/09 06:06 PM
06/12/09 06:06 PM
Missouri, U.S.A.
JSSuperbee Offline OP
Missouri, U.S.A.
Can anyone provide a picture of the front of the damper installed on the crank without the large bolt and a picture of the outside edge of the damper where it is under the timing tab. My tab covers half of the damper, and the damper is about 1/8" from being flush with the end of the crank/snout. I'm trying to determine if my damper is installed all the way.
James Stinebaker
Re: Need picture of front of damper installed [Re: JSSuperbee] #345176
06/12/09 11:38 PM
06/12/09 11:38 PM
Missouri, U.S.A.
Missouri, U.S.A.
Found a picture in a MOPAR rebuild book. Now, how do I prevent rotation of the crank when reinstalling the damper?
James Stinebaker
