Re: Ignition switch? Car only stays running if I hold k
[Re: KGorney]
#345107
06/12/09 05:51 PM
06/12/09 05:51 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
OK that could be the switch or the wiring at the bulkhead connector. 1st check both sides of the ballast resister with a VOM and the key on. Even new ones can be bad. 2nd check the connectors under the dash for voltage with the key on. Does the radio/turnsignals/etc work when in the run position? 3rd If you have voltage at the switch check both sides of the bulkhead connector. Here is a link to wiring diagrams that may help you trace the wires. http://www.mymopar.com/index.php?pid=28
Re: Ignition switch? Car only stays running if I hold key
[Re: KGorney]
#345111
06/12/09 07:52 PM
06/12/09 07:52 PM
Posts: 5,439 So Cal
Sinitro
So Cal
EZ to test with either a 12V test lite or voltmeter. Turn the key to the run position and check if there is 12V @ the ballast resistor. If not... Then start checking backward.. Ballast resistor > bulkhead connector >ignition switch. Just my $0.025..
[Re: Sinitro]
#345112
06/13/09 01:07 PM
06/13/09 01:07 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
if you don't have BRAKE AND OIL ( if oil is not a gauge )on cluster at RUN position, then ign switch is bad.
If you never loose those lights, then problem is on bulkhead or blue wire up to ballast ( including ballast itself )
note, is normal those lights dimming while cranking since ballast is retro feeding the cluster on cranking moment, not ign switch
[Re: NachoRT74]
#345113
06/13/09 01:45 PM
06/13/09 01:45 PM
I can't believe this question got posted as I am having the EXACT same issue with my Challenger right now. I just replaced the ignition switch due to it loosing the dash lights, etc, but it still won't run unless I hold the key just off the start position. The dash lights/clock are working again also. I have already went the ballast resistor route. Thinking by some of the comments here it may be the bulkhead connector. If I find it I'll post out my results so someone else might be able to save some time/money.
#345114
06/13/09 04:25 PM
06/13/09 04:25 PM
NachoRT74
Valencia, España
Lightning net is not feeded by Ign switch, comes directly from batt/alt wiring. So ANY LIGHT issue will never come from Ign switch
[Re: NachoRT74]
#345115
06/13/09 04:31 PM
06/13/09 04:31 PM
NachoRT74
Valencia, España
EDITING!!!
- IF YOU LOOSE THOSE CLUSTER INDICATORS when cranking, PROBLEM IS DEFINITELLY on bulkhead. They should simply dim, but never get lost.
-Being engine is starting, the ballast is good, because power is getting brown wire and then is feeding the blue wire what feeds the Ign Module on engine harness THROUGHT ballast.
- If you loose the cluster indicators on RUN, problem is on Ign switch or some fuse what feeds cluster indicators ( on some models ). Hopwver of course fuse doesn't have something to do with ign itself, just a cluster portection. Of course fuse blown will keep indicators off on any ign position.
[Re: KGorney]
#345119
06/14/09 03:05 AM
06/14/09 03:05 AM
That's cool you found it. I'm going to look at mine later today and hopefully it is just a connection. I also have the extra ECU, ballast in the glovebox too, lol.
#345120
06/15/09 01:26 AM
06/15/09 01:26 AM
Found my problem. The blue wire from the bulkhead connector to the ballast resistor had no voltage. I pulled the connector and found the terminal slightly burned. This harness came from Evans wiring and they crimped the terminal over the insulation and it wasn't making a good connection. Due to the poor connection it drew more amperage and melted the insulation at the terminal. I pulled the terminal out, cleaned it up, recrimped the wire and soldered the terminal/wire. She fired right up and stayed running.
[Re: KGorney]
#345122
06/15/09 08:57 AM
06/15/09 08:57 AM
IMGTX
I had tried the ballast resistor, ECU and coil, since I too, always carry an extra. I ran tests all over with a 12 volt light and it turned out the bulkhead harness connector was slightly loose and corroded on the blades inside. I cleaned the contacts, connected the harness fully and locked it in place, then the car ran fine. Took it out for spin, turned it off and started it a few times and all seems fine.
FYI
If you ever want to replace the terminals NAPA sells them. They are listed as a GM part but are EXACTLY the same as the factory mopar ones.
