Starter Clicking #345016
06/12/09 04:21 PM
06/12/09 04:21 PM
ohio
moparmade43 Offline OP
ohio
Guys, I changed the thermostat in my 416 stroker last quickly outside before the rain, and I quickly rinsed the engine off with light water, where some of the anti freeze spilled over onto my intake and what not. Afterwards, I went to put the car back in the garage and mini starter clicked by didnt spin the engine. Now, even though this didnt make much sense to me, I thought maybe I got something wet, so we pushed it back inside to dry over night. However, this afternoon it will still not start. The mini starter has 500 miles on it. I think this is too big of a coincidence with with me getting the engine wet and it all of the sudden having the only problem i've ever had with it. Any suggestions? I'm going home to try to blow the starter with compressed air. Thanks
Re: Starter Clicking [Re: moparmade43] #345017
06/12/09 04:59 PM
06/12/09 04:59 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
When you gut the starter out remove the steel cover with the three small screws.Then just slide the plunger out and make sure the small copper contacts are clean and the plunger moves smoothly and pushes the pinion gear out.This is all good info provided you have already checked your ground and you have enough voltage at the starter.
Gus
64 Plymouth Savoy
Dana 60
Re: Starter Clicking [Re: fourgearsavoy] #345018
06/12/09 05:02 PM
06/12/09 05:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
bad battery?
Re: Starter Clicking [Re: moparmade43] #345019
06/12/09 05:06 PM
06/12/09 05:06 PM
scratchnfotraction Offline
water has grounded it out
hold the key and have someone "tap" the starter with a hammer,easy taps...
the mini has a round washer disc/plunger rod for a contact and the will get pitted some and do the "clicking" thing
if it loaded with water inside the starter it might have short the contact,the tapping might get it to move..
make sure no water is on the terms of the starter relay ...does it hit by jumping the relay?
I have had a few stock min starters do the clicking and a quike rebuild and a start shop takes car of it
will use same contacs as a yota starter also
my local alt/starter rebuilder got the kit and installs it 65$
might try napa for it also
but then again,if it drys out and works you may be ok
good luck
Re: Starter Clicking [Re: moparmade43] #345020
06/12/09 05:07 PM
06/12/09 05:07 PM
Any suggestions?
keep it simple, turn the headlights on & if they work you have enough battery, shut them off & jump the 2 terminals on the starter(I'm assuming the mini's are like the old style)as I have not had one. No go, pull the starter & I'm assuming your cables didn't corrode that fast that soon.
Re: Starter Clicking [Re: RapidRobert] #345021
06/12/09 05:09 PM
06/12/09 05:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
my truck wouldn`t crank it only clicked and the headlights would light fine. guess what? bad battery
Re: Starter Clicking [Re: moparmade43] #345022
06/12/09 07:39 PM
06/12/09 07:39 PM
ohio
ohio
Sorry guys I should have been more clear, I have a good new battery, it shows 12.5 volts with my meter, and I already bypassed the relay on the fender for the ig. switch. so I know that not the problem. I guess my main question is whether the starter solenoid is bad, or is it possible that water could be laying down on the terminals and grounding it out, or worse could have gotten into it. Unfortunately, the car is upstairs in my buiding and the compressor is downstairs, so I can't blow out with water. being brand new and no prior problems Im hoping and thinking I have a water issue
keeep em comin
Re: Starter Clicking [Re: moparmade43] #345023
06/12/09 08:05 PM
06/12/09 08:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Bad battery or poor battery post connection. Poor ground.
