Best 5.7 / Gen 3 Hemi Tuners/ Techs in San Diego / OC? #344995
06/12/09 03:51 PM
06/12/09 03:51 PM
Kahleefahwniah
69CopperCoronet Offline OP
Kahleefahwniah
I will be needing a Gen 3 Hemi tech in a couple of months to install a comp cams cam and tune the computer. Anyone know a place that is experts on these? It will be going in my 69 coronet.
I really want to avoid going to a stealership, too...
Re: Best 5.7 / Gen 3 Hemi Tuners/ Techs in San Diego / [Re: 69CopperCoronet] #344996
06/12/09 06:48 PM
06/12/09 06:48 PM
houston texas
gremlinsteve Offline
houston texas
its easy...i can send you a write up..do it yourself and save the 700 or so bucks..
what cam did you go with?
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Best 5.7 / Gen 3 Hemi Tuners/ Techs in San Diego / [Re: gremlinsteve] #344997
06/12/09 07:17 PM
06/12/09 07:17 PM
Kahleefahwniah
Kahleefahwniah
that'd be sweet
I chose the comp 268 grind. Advertised Duration 268/ 272, Lift .528/ .531
The rest of the engine will be stock due to budgetary constraints but it should be fun in the coronet backed up by a TCI 727 and eventually some 3.73s
Re: Best 5.7 / Gen 3 Hemi Tuners/ Techs in San Diego / [Re: 69CopperCoronet] #344998
06/12/09 07:54 PM
06/12/09 07:54 PM
houston texas
houston texas
good cam choice.
make sure you use the srt8 exhaust valve spring with it. simple drop in spring. no extra work needed. you can use them on the intake side of that head you have. so you will use 16 of them.
have about 128 on the seat and 360 open.
steve
Re: Best 5.7 / Gen 3 Hemi Tuners/ Techs in San Diego / [Re: gremlinsteve] #344999
06/22/09 01:55 PM
06/22/09 01:55 PM
OH
Red383 Offline
Red383  Offline
OH
Steve, can you post the writup so we all can benifit from it?
thanks.
