Adjusting Kickdown Linkage to Lower Shift Point?
#344982
06/12/09 03:15 PM
06/12/09 03:15 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
Can the kickdown linkage be used to lower the wide open throttle shift point? Last year I relaced the governor on my BB /'65 tranny to raise the shift point. I installed a max wedge piece, and this raised my shift point at WOT from about 4500 rpm to 6000 rpm. I would like to lower this to about 5500-5700 rpm. Can this be done by shortening the linkage slightly?
1979 AMC Spirit, NHRA Q/SA
Re: Adjusting Kickdown Linkage to Lower Shift Point?
[Re: MNobody]
#344986
06/12/09 09:51 PM
06/12/09 09:51 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I agree with this but minor adjustments will lower it.
A goververnor is the best way. Also more consistant with the linkage bottomed out but if you just want to lower the shift points across the board, shorten the rod.
[Re: longram60]
#344987
06/13/09 07:41 AM
06/13/09 07:41 AM
longram60
Dunnellon, FL
Thanks, not a consensus here. I know it has an effect on line pressure, so I wouldn't change it much. I'll do some testing.
