difference in 60 ft tripping clocks w/front or back #344824
06/12/09 12:28 PM
06/12/09 12:28 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
how much difference have you seen between tripping the 60 ft clocks on the back tires opposed to tripping with the front.
Re: difference in 60 ft tripping clocks w/front or back [Re: John Burdine] #344825
06/12/09 12:56 PM
06/12/09 12:56 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
usually about a 1/10
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: difference in 60 ft tripping clocks w/front or back [Re: John Burdine] #344826
06/12/09 01:35 PM
06/12/09 01:35 PM
Mobile Al
Dale Offline
Dale  Offline
Mobile Al
My car normally would go 1.27 and on a long wheel stand will 1.40.
Re: difference in 60 ft tripping clocks w/front or back [Re: Dale] #344827
06/12/09 01:48 PM
06/12/09 01:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
i have seen close to that a few times as well....
the last time i did it, the car went 1.341 the previous pass,not tripping with the backs
on the next pass the car only ran a hundredth different(9.86/9.85) and went 1.459 on the back tires.
Most often a 1/10 but i have had it like the above as well also, almost .12
1.41 best 60 foot
6.56 at 104.17
Re: difference in 60 ft tripping clocks w/front or back [Re: John Burdine] #344828
06/12/09 03:28 PM
06/12/09 03:28 PM
NC
440Jim Offline
440Jim  Offline
NC
I have done it more times than I care to admit. It tends to be 0.10 second on my car. The wheel base (front to back) and the tire diameters (front and back) will make a difference. And of course if it stands straight up, that will effect things more than just carrying the front tires that distance.
Re: difference in 60 ft tripping clocks w/front or back [Re: 440Jim] #344829
06/12/09 08:42 PM
06/12/09 08:42 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well for me it is about a .07 difference. But then again it is arguable as to what is tripping the beams. My best with wheels up, as in the photo I posted a few days ago is 1.27 and without is 1.20. Still a turd in the 60 for a 8teen car. Hope to help that out soon with a gear change.
Re: difference in 60 ft tripping clocks w/front or back [Re: Al_Alguire] #344830
06/12/09 11:18 PM
06/12/09 11:18 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Right at a tenth for me too.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: difference in 60 ft tripping clocks w/front or back [Re: nhramark] #344831
06/12/09 11:22 PM
06/12/09 11:22 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Me too
Re: difference in 60 ft tripping clocks w/front or back [Re: SB412DUSTER] #344832
06/12/09 11:53 PM
06/12/09 11:53 PM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
Me too
Me three
Re: difference in 60 ft tripping clocks w/front or back [Re: Cudafied] #344833
06/13/09 12:30 AM
06/13/09 12:30 AM
Las Vegas
Las Vegas
I wish it was a tenth for me. Something other than the front tires nets me high 1.20's everytime.
Re: difference in 60 ft tripping clocks w/front or back [Re: Al_Alguire] #344834
06/13/09 01:05 AM
06/13/09 01:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
440Jim and myself figured mine one time and on my
short wheel base it was something like .05(I believe)
Re: difference in 60 ft tripping clocks w/front or back [Re: John Burdine] #344835
06/13/09 06:02 AM
06/13/09 06:02 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I wish i had this problem.........ie, tripping the light with the rear tire...
Re: difference in 60 ft tripping clocks w/front or back [Re: 440Jim] #344836
06/13/09 08:52 AM
06/13/09 08:52 AM
NC
440Jim Offline
440Jim  Offline
NC
This attachment show one way to estimate the effect due to distance change from the front to the back tire. The distance "d" is needed, not the wheelbase "w". The beam height "b" and the tire diameters "r1" and "r2" make "d" less than "w". This assumes the same mph at the sixty foot mark. And the car may slow down more if the wheel stand is very high.
But I can't find the details of how we estimated "d". You can estimate the mph from your normal sixty foot time:
mph = 2 x 60/time x3600/5280
Ex:
2 x 60/1.25 x 3600/5280 = 65 mph
This assumes the acceleration is constant (which it is not), and the speed at the mark is twice the average speed (which is what this calculates).
Re: difference in 60 ft tripping clocks w/front or back [Re: 440Jim] #344837
06/13/09 03:55 PM
06/13/09 03:55 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Jim,
No offense but I think you are just way to smart for the rest of us!!! If I ever tripped the 60' clock with the back tires I would not be able to talk due to the joker type smile on my face!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
