Can I switch tranny fluid ? #344641
06/12/09 09:13 AM
06/12/09 09:13 AM
NE Oklahoma
71valiant Offline OP
NE Oklahoma
When I put my car together I put dexron III in my 727. It shifts alittle softer than I want even with the shift kit. I was thinking of switching up to F as I heard it makes shifts alittle firmer.
Re: Can I switch tranny fluid ? [Re: 71valiant] #344642
06/12/09 09:26 AM
06/12/09 09:26 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is it slipping ??? Hard banging shifts are NOT a sign of a good shifting trans , and it actually gets annoying overtime if the car is your DD .
But yes you can drain out the dex and switch to type F , get out as much of the dex as possible before refilling the system .
