What's your take on this engine?
#344569
06/12/09 07:45 AM
06/12/09 07:45 AM
Posts: 136 Ontario, Canada
500ciBee
Ontario, Canada
Price is $14500. What do you guys think? I haven't started my build yet and started looking around for a complete engine. Thanks
YOU ARE BIDDING on a MOPAR 400 to 500 cid STROKER COMPLETE DYNO-TESTED ENG 746HP @ 6000 RPM and 697 ft/lbs TQ @ 4800 RPM ON PUMP GAS!
OEM 400 BLOCK, EDELBROCK MAX-WEDGE HEADS
* CNC MACHINED ON ROTTLER F65A * CLEARANCE LIFTER BORES * INDY BILLET REAR MAIN SEAL ASSEMBLY * 400 MAIN GIRDLE ASSEMBLY * MILODON ADJ OIL PRESSURE REG. * EDELBROCK 77929 MODIFIED TO MAX-WEDGE * CYLINDER HEADS MAX-WEDGE PORTED * COATED COMBUSTION CHAMBERS * COATED VALVE FACES & STEMS * 2.250 INTAKE VALVES & SPECIAL VALVE TRAIN * 4.150" STROKER CRANKSHAFT 4340 * 4340 FORGED H-BEAM RODS * FULL FLOATING PISTON PINS * PUMP-GAS DIAMOND FORGED COATED PISTONS * TOTAL SEAL GAPLESS TOP FILE TO FIT RINGS * CUSTOM SOLID ROLLER CAMSHAFT * HUGHES SHAFT ROCKER SYSTEM * MOPAR PERFORMANCE VALVE COVERS * HIGH VOLUMN OILING SYSTEM * SMITH BROS PUSHRODS * 1.540 VALVE SPRINGS * SOLID ROLLER LIFTERS * MANLEY VITON SEALS * INDY PORT MATCHED MAX-WEDGE INTAKE * CUSTOM PC POWDER-COATED CARB * INDY VALLEY TRAY, ARP FASTENERS * MSD 8546 BILLET DISTRIBUTOR * 3 BOLT BILLET TIMING SET * MILODON 30890 PAN WITH PICK-UP * COATED GROOVED BEARINGS * FELPRO GASKETS, ARP FASTENERS * ATI SFI SUPER HARMONIC DAMPER * MILODON BRONZE GEAR * BALANCED ROTATING ASSEMBY * SPEEDOMOTIVE EXPERT ASSEMBLY * DYNO-TESTED ON 91 OCTANE * 746HP @ 6000 RPM * 697 ft/lbs TQ @ 4800 RPM * CALL FOR DETAILS
ADDITIONAL INFORMATION AVAILABLE. CALL US AT 626-869-0270, ASK FOR GEORGE. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing [ask for George].
SHIPPING is FIGURED AT AUCTION END EXACT DEPENDING ON YOUR ZIP CODE. CALL OR EMAIL US FOR A PROMPT QUOTE. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing.
Engine building by Speedomotive using zero deck quench motor technology. If you would like to know the engine building secrets, specifically the ones used in this ebay listed item, click here>> SPEED SECRETS
Compression ratio is figured at zero deck quench motor build: To check our math, click here>> TECHNICAL INFORMATION
Seller accepts Paypal, Cashier's Check, Money Order, Visa/Master Card/Discover or
AT AUCTION END YOU MAY CALL SPEEDOMOTIVE @ 1-626-869-0270 TO USE YOUR CREDIT CARD AND GET FAST SERVICE.
Our ebay store has many other engine builds, check it out, click here>> EBAY STORE
SPEEDOMOTIVE is interested in YOUR engine build project. We are friendly and helpful to talk to. We THANK YOU for looking at this ebay listing. We would like to hear from you. Call SPEEDOMOTIVE @ 1-626-869-0270 if you have questions about this ebay listing.
FOR TECHNICAL INFO REGARDING THIS LISTED engine build, CALL George @ 1-626-869-0270
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: What's your take on this engine?
[Re: 500ciBee]
#344571
06/12/09 08:54 AM
06/12/09 08:54 AM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
what exactly is a "special" valvetrain?
[Re: 70blackfish]
#344573
06/12/09 09:39 AM
06/12/09 09:39 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I have seen a couple of horror stories on here about Speed o motive
X2
[Re: boatracer572]
#344575
06/12/09 10:13 AM
06/12/09 10:13 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
to much money for a build around a"stock" 40 year old block
x10---way too high!
[Re: hemiiroc]
#344576
06/12/09 11:04 AM
06/12/09 11:04 AM
JohnRR
U.S.S.A.
x10---way too high!
I agree with that also , old tech build , should be a 4.25 stroke crank with BBC spec rods plus coatings that aren't really required and I'd be curious if they were really in there , plus I would want to WITNESS the actual dyno session on the actual motor ...
[Re: Bob_Coomer]
#344578
06/13/09 08:58 AM
06/13/09 08:58 AM
500ciBee
Ontario, Canada
Thanks guys!! Our plan was to build a 500-512 stroker using a 400 block. Logistically it's been tough getting the time set aside to work on the build. Living in Ontario, Canada parts are more expensive to buy and ship. Also, I know of a few machine shops around but most seem to cater to the Mustang(ford) crowd.
We have a fairly strong running 383 with some good reusable parts to build our extra 400 into a 512. I'd much rather be apart of the build and not spend $14500 or $16500cdn if I don't have to.
Can you guys recommend a good shop in the Toronto, SW Ontario, area that have experience building Mopars? Thanks!!
[Re: JohnRR]
#344579
06/13/09 10:19 AM
06/13/09 10:19 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
X2
The member on here that bashing Speed-O-Motive had some serious credibility problems. He apparently was a scammer and constantly changed his Moparts screen name to cover up some of the shoddy deals he had in the classifieds. Most of what he claimed about the S-O-M motor were lies. '68fastback' can fill in some of the details.
[Re: 500ciBee]
#344580
06/13/09 10:38 AM
06/13/09 10:38 AM
Posts: 1,397 Toronto Ontario, Can
Glen440
I have been using a shop in Aurora. They do build some Mopars but they mainly do stock car stuff and cylinder heads. I just have them do machine work and cylinder head freshen ups and I assemble the engine.
I'll be dropping a block off there next week.
87 dakota 6.1 hemi
[Re: B5 Bee]
#344581
06/13/09 10:58 AM
06/13/09 10:58 AM
Posts: 3,695 nc
emarine01
nc
A few years ago a buddy hydro locked a 360 stroker he got from them , He had a bad carb , flooded it and bent a rod cranking , He got it as a short block for around 3k , I fixed it for him and cant say that anything was out of spec or poorly done, not my choise of parts but thats what they said was it for 3k,I am not defending the builder but IMO there are two sides to every story and its not really fair if the builder cant represent himself , as far as the big stroker goes, I dont think its worth the big bucks outa a stock block
[Re: Bob_Coomer]
#344582
06/13/09 06:04 PM
06/13/09 06:04 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I agree, I could build that engine for around that price with a aftermarket block. And going with a cheaper stroker kit, end up with 572 cubes
I agree
Rickster
[Re: Joshs68]
#344585
06/13/09 09:49 PM
06/13/09 09:49 PM
PM arc on the board, he has a new 572 with a megablock that dynoed 931 hp with 572-13 indy heads for that price.all top of the line parts too.
[Re: B5 Bee]
#344587
06/14/09 03:34 AM
06/14/09 03:34 AM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
X2
That wingnut is still on here after burning one member on a car and trying to do the same with another car. He always attacks the truth.
But for that amount of money check around especially on here you should be able to maximize your money in these times. Good luck.
