Front runner wheels #344422
06/11/09 10:45 PM
06/11/09 10:45 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
What are you running for a front runner with a 2 1/4" backspace?? I really like the weld 786-15202 but they are about a G for a pair Is there anything else available with a larger bs on a 3.5" wheel?
Re: Front runner wheels [Re: JandJ_Racing] #344423
06/11/09 11:52 PM
06/11/09 11:52 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
weld draglites are made with that b/s also ~ $.5G
Re: Front runner wheels [Re: JandJ_Racing] #344424
06/11/09 11:59 PM
06/11/09 11:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
John did you check the BS theory or are you just looking?
Re: Front runner wheels [Re: MR_P_BODY] #344425
06/12/09 07:29 AM
06/12/09 07:29 AM
Way North Illinois
Way North Illinois
Mike I milled off 11/16 to tuck the ball jount in closer to the wheel but I still have a shake
Re: Front runner wheels [Re: JandJ_Racing] #344426
06/12/09 07:40 AM
06/12/09 07:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Has it lessened with removing the 11/16?
Re: Front runner wheels [Re: MR_P_BODY] #344427
06/12/09 08:54 AM
06/12/09 08:54 AM
Way North Illinois
Way North Illinois
It seems better
Re: Front runner wheels [Re: JandJ_Racing] #344428
06/12/09 10:35 AM
06/12/09 10:35 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Hi John, did you check your scrub angle?
Lay under your car at ride height and take a small staight edge in line with the center of the top balljoint and line it up through the center of the bottom balljoint. See where it hits the ground in relation to the front tire.
Where was it before you removed 11/16"?
I think Lee milled the back side of his spindle .250" and the different BS wheels made a difference = .750" Don
Re: Front runner wheels [Re: JandJ_Racing] #344429
06/12/09 11:37 AM
06/12/09 11:37 AM
Locomotion Offline
Locomotion  Offline
Holeshot Wheels can do just about anything you would need with wheels!
Holeshot Wheels website
Re: Front runner wheels [Re: cudadon] #344430
06/12/09 01:17 PM
06/12/09 01:17 PM
Way North Illinois
Way North Illinois
Hey Don
I thought it fell in the tire now but I kind of hurryied to get it out to the track. The 11/16 includes a 1/2" plate that the steering arm attatches to so I am only 3/16" farther out than stock if that makes sense.
Re: Front runner wheels [Re: JandJ_Racing] #344431
06/12/09 08:31 PM
06/12/09 08:31 PM
Way North Illinois
Way North Illinois
Not far enough into the tire???
Re: Front runner wheels [Re: JandJ_Racing] #344432
06/12/09 08:35 PM
06/12/09 08:35 PM
Way North Illinois
Way North Illinois
Maybe a slightly better picture. car is inside the trailer, lol
Re: Front runner wheels [Re: JandJ_Racing] #344433
06/12/09 08:43 PM
06/12/09 08:43 PM
Way North Illinois
Way North Illinois
took some more pics
Re: Front runner wheels [Re: JandJ_Racing] #344434
06/12/09 08:44 PM
06/12/09 08:44 PM
Way North Illinois
Way North Illinois
last one
Re: Front runner wheels [Re: JandJ_Racing] #344435
06/13/09 12:14 AM
06/13/09 12:14 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
CAP front end?
Re: Front runner wheels [Re: JandJ_Racing] #344436
06/13/09 09:21 AM
06/13/09 09:21 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Hey Don
Yeah that makes sense. The question is what BS wheel did the factory use? Compared to what you got now. The second to last pic was a good shot of where the scrub angle is.
I may go to Cordova today, will look at my scrub before I load up.
There are a lot of things to engineer when building a K frame, front steer! Don
Re: Front runner wheels [Re: cudadon] #344437
06/21/09 10:18 PM
06/21/09 10:18 PM
Way North Illinois
Way North Illinois
Update:
Car not run yet but here is an updated SIA picture with a line drawn.
Re: Front runner wheels [Re: Locomotion] #344438
06/21/09 10:22 PM
06/21/09 10:22 PM
Way North Illinois
Way North Illinois
Thank you that is what I went with. Only wheel that I saw that had a 2.875 bs and looked like the Weld draglights I was allready running.
