Anyone use Lamb Banjo fittings? #344416
06/11/09 10:28 PM
06/11/09 10:28 PM
Out West
408strokerdart Offline OP
Out West
I am having a tough time trying to get the banjo fittings to stop leaking brake fluid at the master cylinder. It appears to be leaking between the aluminum crush washer and the master cylinder. I inspected the master cylinder machined surface pretty good before installing and everything looked good. Anyone else have trouble sealing these up and what did you do to fix it?
Re: Anyone use Lamb Banjo fittings? [Re: 408strokerdart] #344417
06/11/09 10:31 PM
06/11/09 10:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Try a copper washer instead.
Re: Anyone use Lamb Banjo fittings? [Re: Al_Alguire] #344418
06/11/09 10:49 PM
06/11/09 10:49 PM
Out West
Out West
Do they do a better job of sealing? Are they softer?
Re: Anyone use Lamb Banjo fittings? [Re: 408strokerdart] #344419
06/11/09 10:51 PM
06/11/09 10:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Worked better for me when we had the same issue. Your mileage may vary
Re: Anyone use Lamb Banjo fittings? [Re: Al_Alguire] #344420
06/11/09 11:10 PM
06/11/09 11:10 PM
Out West
Out West
OK, thanks Al. I had someone else suggest that and I thought they were crazy. I guess I will try it.
