383 ValleyPan Gasket w/Blocked Heat Crossover Question #344141
06/11/09 03:20 PM
06/11/09 03:20 PM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
It is made by Fel-Pro,do you have to run gaskets with these or just seal up the 4 corners and go? Thanks all.
'71 383HP FJ6 Charger SE
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: 71 FJ6 Charger] #344142
06/11/09 03:26 PM
06/11/09 03:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
seal the 4 corners and go .
BUT what type of choke are you using ? The factory STOCK unit will not work properly if at all
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: JohnRR] #344143
06/11/09 04:23 PM
06/11/09 04:23 PM
NE Ohio
NE Ohio
Holley with manual choke,if any at all. Thanks
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: 71 FJ6 Charger] #344144
06/11/09 04:33 PM
06/11/09 04:33 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Is this a street car? ...which intake manifold?
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: dOoC] #344145
06/11/09 04:35 PM
06/11/09 04:35 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I used them on my 440 with my aluminum Eddy CH4B
1MYTGTX
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: 1MYTGTX] #344146
06/11/09 06:19 PM
06/11/09 06:19 PM
NE Ohio
NE Ohio
Stock intake,or the old CH4B or whatchya call it for a B motor if I find one at the shows.I know the pros' n' cons',dont need specifics. I dont drive in the winter other than starting once a month or so,and it'll help in the summer. Thanks all.
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: 71 FJ6 Charger] #344147
06/11/09 07:00 PM
06/11/09 07:00 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I run the gasket between the head and the aluminum pan gasket. The heads have been milled a little so it justs give me some extra insurance no oil gets sucked. At least put a thin layer of sealant on the head to help yourself sleep easier at night!!
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: Viol8r] #344148
06/11/09 07:20 PM
06/11/09 07:20 PM
I use permatex #2 on both sides of the tin valley gasket SPARINGLY. Many run them as is w no issues but I dont think that the tin is pliable enough to seal well on it's own . I would mock it up 1st & check the port alignment & mill the intake/head face to correct it.
Re: 383 ValleyPan Gasket w/Blocked Heat Crossover Question [Re: Viol8r] #344149
06/12/09 09:03 AM
06/12/09 09:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is what I do PLUS it INSULATES the intake from direct contact with the pan to help keep it cooler .
As long as you use either a manual choke or an electric choke you'll be FINE blocking the crossover.
I wouldn't waste the gas starting it up once a month during the winter
