Valve Springs for MP .508 cam #343983
06/11/09 11:04 AM
06/11/09 11:04 AM
Rome, PA
randydemon Offline OP
Rome, PA
What valve springs do I need for a 360 with a MP .508" purple shaft cam?
Re: Valve Springs for MP .508 cam [Re: randydemon] #343984
06/11/09 02:07 PM
06/11/09 02:07 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
You need something around 110 lbs on the seat
at your installed height. Call Mancini they
have the springs.
logan426
Re: Valve Springs for MP .508 cam [Re: randydemon] #343985
06/11/09 02:09 PM
06/11/09 02:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
MP catalog recomends MP P5249847 spring valve
spec for those is:
http://www.summitracing.com/parts/DCC-5249847/
so I guess any spring ( if you don't want MP ) with similar specs will work
Re: Valve Springs for MP .508 cam [Re: NachoRT74] #343986
06/11/09 02:13 PM
06/11/09 02:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
more specs for those
Re: Valve Springs for MP .508 cam [Re: NachoRT74] #343987
06/11/09 02:15 PM
06/11/09 02:15 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
spec for those is:
yeah..at 18 dollars each i would find another spring.
try comp 901 or hughes 1110
http://www.hughesengines.com/Index/products.php?browse=search&search=1110&partid=10280
Re: Valve Springs for MP .508 cam [Re: 70AARcuda] #343988
06/11/09 04:44 PM
06/11/09 04:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Suggested retail is only 12 apiece at a Chrysler dealer. Whoever is trying to get 18 bucks apiece for them is smoking something
