Are T/A Rocker Arms legal on F.A.S.T. 71 Duster 340? #343951
06/11/09 10:31 AM
06/11/09 10:31 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Just curious if you could use T/A or another offset Rocker Arm an re locate the push rods holes and still be legal on F.A.S.T, non T/A car, such as a 1971 Duster 340. In other words cloning a T/A head. Thanks.
Re: Are T/A Rocker Arms legal on F.A.S.T. 71 Duster 340? [Re: ragtop] #343952
06/11/09 10:33 AM
06/11/09 10:33 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
As long as you start out with the correct head, and it appears stock on the outside, and the original, correct casting # remains, you can do whatever you want to the inside of the head.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Are T/A Rocker Arms legal on F.A.S.T. 71 Duster 340? [Re: Hemi_Joel] #343953
06/11/09 10:45 AM
06/11/09 10:45 AM
NY
aarmaniac Offline
aarmaniac  Offline
NY
They can look like these.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
Re: Are T/A Rocker Arms legal on F.A.S.T. 71 Duster 340? [Re: aarmaniac] #343954
06/11/09 10:47 AM
06/11/09 10:47 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
those are some funky spark plugs
Re: Are T/A Rocker Arms legal on F.A.S.T. 71 Duster 340? [Re: ragtop] #343955
06/11/09 11:01 AM
06/11/09 11:01 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Just make sure you use T/A style rockers. (Harland Sharp)
Any W-2 rocker I've tried, you still have to relocate
the shafts and pushrods end up in the manifold face.
