SAE 40 or 20W-50 Valvoline racing oil? #343913
06/11/09 10:09 AM
06/11/09 10:09 AM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
Which one for my 360 which will only see street use and not be driven in cold weather?
Any differences or is it pretty much a tossup?
I prefer this brand oil due to it's higher levels of ZDDP.
TIA
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: MY340] #343914
06/11/09 10:16 AM
06/11/09 10:16 AM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Royal Purple 10W-40
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: MY340] #343915
06/11/09 10:23 AM
06/11/09 10:23 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
You can get the VR-1 in a 10-40 and other weights also. I just bought a case for my Dakota. Napa had to order it in. They got it overnight. Cost around $45.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: Posest] #343916
06/11/09 10:41 AM
06/11/09 10:41 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
If your engine was built with close tolerances,why would you want to use such a thick oil? Especially on an engine that will mainly see low R.P.M.'s.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: Mr. T] #343917
06/11/09 11:32 AM
06/11/09 11:32 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Don't run the heavy goop.
run the 20-50 or order something like 10-40 like was said.
I want my fair share
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: SomeCarGuy] #343918
06/11/09 11:53 AM
06/11/09 11:53 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Run the lightest weight oil you can for best flow at start-up; I've been running 10W-30 for decades, even in the racecar and never a problem. the heavier the oil viscosity, the more power and fuel you'll use pumping it. I'm assuming your bearing clearances & oil pressure are normal.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: MY340] #343919
06/11/09 12:54 PM
06/11/09 12:54 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
VR1 10w30
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: deansrr] #343920
06/11/09 01:17 PM
06/11/09 01:17 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
When I owned Mopars in the 70's , I always used a 20w-50 oil. Back then it was Kendall GT-1 ( now Brad Penn). I now use Valvoline Racing 20w-50 for the same reasons you cited.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: deansrr] #343921
06/11/09 01:41 PM
06/11/09 01:41 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
That's what my engine builder said, and NAPA is the place to get it.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: 1fastrunner] #343922
06/11/09 08:01 PM
06/11/09 08:01 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I recommend the 20-50.. everyone has a personal choice, but if you ever get stuck in traffic or your engine simply runs hot the 10w stuff turns to water and cannot protect like a heavy vis. oil.
Any extreme activity like high RPM or heavy loading or a short period with no oil, like start up or starvation, requires the most protection you can get, not the least you can get by with..
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: sthemi] #343923
06/11/09 08:09 PM
06/11/09 08:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would recommend 15/40 or 10/40 most applications unless you are running with a lot of bearing clearance you don't need any heavier oil.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: MoparforLife] #343924
06/11/09 08:49 PM
06/11/09 08:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would NOT use anything that has the numbers 40 or 50 in a tsreet engine.
Any so called engine builder still building street motors with clearances so loose you HAVE to run thick oil is not an engine builder IMO but an engine butcher.
Don't be the exception.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: Supercuda] #343925
06/11/09 09:04 PM
06/11/09 09:04 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
FWIW I just used the 20w-50 VR-1 in my 440....I was running Rotella 15w-40 in it since it was rebuilt about 6k miles ago....
Switched because of the better Zinc levels in this stuff
1MYTGTX
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: 1MYTGTX] #343926
06/11/09 11:44 PM
06/11/09 11:44 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
20w 50 VR1 user here.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: 1MYTGTX] #343927
06/11/09 11:45 PM
06/11/09 11:45 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The 10W-30 VR1 is only three viscosity points lighter than the SAE 40 VR1 @ 212 degrees (F), which is considered to be normal operating oil temp.
At 100 degrees (F), the SAE 40 VR1 is 59.8 viscosity points thicker than 10W-30 VR1.
The better flow of the 10W-30 VR1 at cold engine start-up (even at 100 degrees (F) will protect your engine better considering both oil viscosities at operating temp are so close.
In a street car, your motor oil operating temp (not to be misconstrued with coolant temp) will hardly ever see 212 degrees (F).
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: MY340] #343928
06/12/09 03:08 AM
06/12/09 03:08 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
20W-50
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: Mr. T] #343929
06/12/09 09:36 AM
06/12/09 09:36 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Even factory tollerences should only require 10w 30 or 10w40.
20w 50 is too thick in a fresh motor
As for straight weight's(sae 40, etc..) they are for lawn mowers, given the availability of much better modern stuff.
Re: SAE 40 or 20W-50 Valvoline racing oil? [Re: dave571] #343930
06/12/09 11:31 AM
06/12/09 11:31 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you ask 20 different people,you'll get 20 different answers.Anyone ever read an owners manual?
Also,as far as zinc content is concerned,everyone will tell you theirs is best.Do what I did with Brad Penn,pay to have an analysis done then you will know.
