Page 3 of 3 1 2 3
Re: Losing Oil Pressure upon luanch [Re: QuickBpBp] #343446
06/12/09 02:24 PM
06/12/09 02:24 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
dropped my pan today measure block pan rails to pick up 4.125 measured pan depth 4.875 (pan is a 971)meaning the pick up was .75 off the bottom of pan. Neighbor had a 402 pan I installed it (the price was right free)the pick up is now sitting on the bottom of the pan. Gotta go get some oil and see what happens
Re: Losing Oil Pressure upon luanch [Re: flatiron] #343447
06/12/09 10:57 PM
06/12/09 10:57 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Put 5 quarts of 15w-40 in pan fired up about 78 lbs of Oil Pressure at 2500RPM. Pulled up to make a hard luanch Oil pressure stayed right up there. The cause of my headache Mismatch pickup to oil pan.
Thanks to everyone for their input
Re: Losing Oil Pressure upon luanch [Re: flatiron] #343448
06/13/09 12:12 AM
06/13/09 12:12 AM
MNobody Offline
MNobody  Offline
Glad it's fixed but it sounds like your walking a fine line, 3/4 of an inch in the pan equals what? about a half a quart of oil?
Re: Losing Oil Pressure upon luanch [Re: flatiron] #343449
06/13/09 12:30 AM
06/13/09 12:30 AM
any idea how it ended up w that much clearance?
Re: Losing Oil Pressure upon luanch [Re: RapidRobert] #343450
06/13/09 08:01 AM
06/13/09 08:01 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I would have to say the prior owner put the wrong pan/pickup on.
Page 3 of 3 1 2 3
