Losing Oil Pressure upon luanch, problem fixed HOW
#343406
06/10/09 05:53 PM
06/10/09 05:53 PM
Posts: 724 PA USA
flatiron
PA USA
I have a 431 and while Driving at 2500 rpm my oil pressure holds at 62lbs. When I luanch from a red light it drops to 0 Then comes back up after 20 seconds or so. I have a aftermarket gauge and I noticed some air bubbles in the line could it be this or should I be looking at something else?
Re: Losing Oil Pressure upon luanch
[Re: flatiron]
#343407
06/10/09 05:55 PM
06/10/09 05:55 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Do you have baffles in the oil pan and a windage tray?? How far off the floor of the pan is your sump and do you have a deep oan??
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: flatiron]
#343410
06/10/09 06:15 PM
06/10/09 06:15 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I agree with the other posts, you are uncovering the pick up screen.Baffles and a tray are mandatory.One more item to check is the pick up tube itself. It must be tight (and sealed) in the block and without any cracks.A few of those uncoverings could be very costly.Needs to be repaired asap.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#343414
06/10/09 06:48 PM
06/10/09 06:48 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
A tray ? ...is way WAY toooo high to control oil movement. It was designed for and is only good to get the oil AWAY from the rotating assembly.
You need baffles and "doors" to keep the oil in the area of the PU tube opening.
Windage not movement.Normal street pan can not keep the oil far enough away from the crank.Windage can add to the problem.
I am not following what you are saying.
I would AGREE that windage is an issue ... but not HERE ... with the OP's problem.
[Re: BeEtLeJuIcE !]
#343416
06/10/09 07:22 PM
06/10/09 07:22 PM
mike s
Mi,U.S.A.
I addressed the problem.These issues shouldn't be a problem.Everything I mentioned should be a part of any performance build.I was speaking in the builds' totality. Moroso and Milodon (and others)have nice 7 inch deep pans that fits early and late chassis.At the least any serious perfromance build should have a Street Hemi pan (6qts)if you are going to hammer the combo IMO. Stop yelling if someone would have informed the writer during the build he would not have the problem he does IMO
[Re: flatiron]
#343417
06/10/09 07:25 PM
06/10/09 07:25 PM
mike s
Mi,U.S.A.
Yes,a bit of work but not too bad. Easier if you drop the centerlink and lift the engine slightly.
There are no stupid questions on Moparts. We all can learn something here.
[Re: flatiron]
#343420
06/10/09 08:17 PM
06/10/09 08:17 PM
BeEtLeJuIcE !
Florida STAYcation
Your first priority should be getting a good HP oil pan.
And when you R&R the old pan ... I would check a couple of bearings. Letting a motor run(especially under WOT) and having to wait for the oil-pressure to come-back to normal COULD NOT have done the bearings any good.
