Body Gaps #343336
06/10/09 04:36 PM
06/10/09 04:36 PM
Wisconsin
Mopar Mark Offline OP
Wisconsin
I am installing new AMD quarters, Deck lid, Trunk gutters, and Filler panel on a 70 Challenger. The door to quarter gaps are at 3/16 and look good. The best I can get for quarter to deck lid is 1/4 which looks a little too big. What is an acceptable body gap. I know they were not great on these cars even when new but I would like to know if this is acceptable.
Thanks,
Mark
1970 Challenger R/T 440-4 Auto 2000 Ram Quad Cab 4x4 360 Auto 1973 Dodge 1/2 ton 4x4 318 Auto 1995 Dodge Dakota 4x4 318 Auto
Re: Body Gaps [Re: Mopar Mark] #343337
06/10/09 05:30 PM
06/10/09 05:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
1/4" sounds tolerable so long as it's consistant.
There are ways to correct the gaps if your willing to do the work. This is the trunklid to quarter gap on my brother's 68 Olds. They sliced it with a cut off wheel and then pryed it over and rewelded fixing the uneven gap in the process.
After welding. The metal still needs to be smoothed over, but you get the idea.
Re: Body Gaps [Re: Neil] #343338
06/10/09 06:33 PM
06/10/09 06:33 PM
Wisconsin
Wisconsin
One side is real nice and straight and the other side is not. I think I will take my time and get it right now.
Thanks,
Mark
Re: Body Gaps [Re: Mopar Mark] #343339
06/10/09 06:35 PM
06/10/09 06:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks,
Mark
1/4" is fine,....make allowences for primer and paint build up, esp if using high build primers, and premium based BC/CC as they will have a heavier volume or build on edges,......3/16", looks nice but can quickly become 1/8" after all the paint work,....and if it's on the edge turning into a panel (front door edge for ex.), the paint may contact and chip,....with the "tolerances/panel shape/contour" of older cars I personally shoot for 1/4" gaps on raw steel edges, knowing when I'm done painting the car, the gaps will be approx 3/16 finish
Re: Body Gaps [Re: DAYCLONA] #343340
06/10/09 06:56 PM
06/10/09 06:56 PM
Wisconsin
Wisconsin
Thanks, I never thought about allowing for the primer and paint build up. That makes me happy, I only need to straighten one edge. I can adjust the doors and fenders to achieve 1/4" all around.
Thanks again,
Mark
