Re: K-H replacement rotors in 4.5" BP or 4"??
[Re: DusterW2]
#343244
06/10/09 04:19 PM
06/10/09 04:19 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
http://www.rockauto.com/dbphp/mfr,RAYBESTOS,Brake%252FWheel%2BHub,13714,Brake%2BRotor%2BShim
AUTOSPECIALTY / KELSEY-HAYES Part # AR8305 Front; DUSTER; VALIANT [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)
Better hurry , it looks like the rumor of them going away is true, I bought 4 a couple years ago as a just in case ...
[Re: 68Fastback]
#343246
06/11/09 08:25 AM
06/11/09 08:25 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I thought I heard there was a similar vintage mustang rotor you could use with some creative bearing selection and get LBP with the KH disks....
[Re: patrick]
#343247
06/11/09 10:46 AM
06/11/09 10:46 AM
JohnRR
U.S.S.A.
SSBC has a rotor , I borrowed a mustang rotor from a local parts store and tried it but it takes more than just some creative bearing selection , the rotor it self needs machining best as I could tell. First off the A body spindle is a little short so the bearing depth would need to be adjusted then the OD of the rotor itself is bigger than the stock A body rotor and you can't bolt the caliper on , not sure whats different about the mustang caliper and if it would bolt to the mopar spindle .
