New engine smoking
#343185
06/10/09 12:08 PM
06/10/09 12:08 PM
Posts: 2,405 Lee Co. Fla.
5carguy
Lee Co. Fla.
Here's one for the books,a one in a million problem that no one seems to have an answer for.I'm sure with all the engine builders out there someone has to have an answer.Here goes,the engine is a 1971 340 cu.in.bored.060(10.5 to 1 Ross pistons) with a stroker kit ending in 420 cu.in.Indy Edelbrock heads,Mopar perf. tri power intake,Promax carbs,Comp Cams hyd. roller cam.HERES THE PROBLEM,on initial start up it started smoking a little and then really started smoking.I let it run for about 15 to 20 min to let the rings seat with no change in the smoking.After cool down I pulled the intake and in the intake runners it was wet with oil.Also behind the intake valves(the ones that were closed)was at least a 1/8 to 1/4 inch puddle of oil.At first I thought the intake to head surface was off, so I had a machinist resurface it.No change,I changed the intake No change.I've done everything from leak down tests to compression tests and all is fine.I've had this engine out and appart 3 times and checked everything 10 times.All parts are new.I've taken the block and heads to 2 different automotive machinists and everything checks out fine.Everyone I have talked to has no idea what the problem could be.I have a Lot of money and time invested in this and still have problems.I hope I haven't bored you to much with this but I have been trying to figure this out for months. I have built many engines over the years but never had a problem I couldn't figure out.This has got me.ANY HELP WOULD GREATLY BE APPRECIATED. Thanks in advance Bob
Re: New engine smoking
[Re: 5carguy]
#343186
06/10/09 12:13 PM
06/10/09 12:13 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Valve seals?
is the PCV valve have a baffle inside the valve cover? maybe it's sucking oil windage into your intake?
does your intake have a hole in it somewhere? where it's open into the valley of the block? maybe just a small crack that you can't see, then when it heats up it opens up enough to suck in massive amounts of oil?
I don't know where else you could get oil into the intake on a small block
**Photobucket sucks**
[Re: 5carguy]
#343188
06/10/09 02:08 PM
06/10/09 02:08 PM
Posts: 833 MN
hemidup
MN
I had the same problem that your discribing with a sreet engine build a few years ago. On the first start up, it smoked just a tad bit but the smoking just got worse over the next few minutes so I shut it down. I went through all the trouble shooting that you've gone through and after a few weeks of pulling my hair out, I called Perfect Circle who I bought the rings from and found out that I had to change out my 2nd rings. I normally used the light tensil Perfect Circle rings on low vaccumm engines, however this street motor was high vaccumm and the 2nd ring wasn't doing its job. Perfect Circle sent me out a different 2nd ring pack and all has been good ever since.
Jerry Williams.
[Re: 5carguy]
#343189
06/10/09 02:10 PM
06/10/09 02:10 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
There's only three ways to get oil in the runners, intake/head mating area, valve seals or PCV valve. I'd look in the area of the mating surface between the head & intake. It's either too wide of a gap or the angle is off.
[Re: 5carguy]
#343191
06/10/09 02:46 PM
06/10/09 02:46 PM
What type oiling system is in the motor, high volume or high presure pump?? how much oil, try running it one quart low , are you running a evac system? Presure is pushing oil past the oil ring.
[Re: 5carguy]
#343195
06/10/09 03:30 PM
06/10/09 03:30 PM
Posts: 5,080 organ
maximum entropy
organ
is the pcv fitting baffled in the valve cover?
[Re: 5carguy]
#343197
06/10/09 03:51 PM
06/10/09 03:51 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i would ditch the PVC and see how it is
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#343198
06/10/09 04:51 PM
06/10/09 04:51 PM
Posts: 2,524 PA
moparacer
PA
Warm it up, pull the plugs and do a leakdown on all the cylinders....
I just cured a smoking problem last week I had and it was the header evacs sucking oil....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: sixpackgut]
#343199
06/10/09 08:33 PM
06/10/09 08:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
you have oil in the intake system, you already changed the intake, pull and plug the PCV port
[Re: emarine01]
#343203
06/11/09 10:02 AM
06/11/09 10:02 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Depending on the cams overlap a cracked spring seat leaking into an intake port can move oil into the plenum and foul other cyls
So can a ring and/or piston problem. I had a 440 that was smoking... it had hurt a piston and scarred up a cylinder wall badly. When you removed the intake you could see oil sitting on the intake valves of a few cylinders. CHIP
[Re: an8sec70cuda]
#343204
06/11/09 11:13 AM
06/11/09 11:13 AM
70Cuda383
Marysville, O-H-I-O
how's this for "pulling fluids accross the intake"?
when I hydro locked my motor from a cracked cylinder, I thought it was #6, because that's where the bent pushrods were, as well as the lifter that got tossed. pulled the engine apart, and the crack was in #3!!!
the water sucked out the intake valve, and into the manifold, accross the engine, and went into #6!
at first I thought "great, I have 2 cracks/water leaks" but the machine shop couldn't find anything wrong with the heads, no signs of a leaky head gasket, and no other cracks in the block.
sleeved #3, and have since put 3,000 miles on it without issue.
If I didn't see it with my own eyes, and have it happen to me, I would STILL call BS if someone told me that water could get sucked OUT of a cylinder, accross the manifold and into a cylinder on the opposite bank!
