440-6 surging
#343146
06/10/09 10:42 AM
06/10/09 10:42 AM
just had the three carbs tunes with timing set at 12 degrees, total advance at 38 degrees at 2600 rpms, new Taylor plug wires, new Champion plugs, new pointless ignition. When I left the shop yesterday the car ran great, when I started it this morning I have noticed a steady surge at idle and cruising. At idle I hear a slight popping out the tail pipes. Does anyone have an idea.
Re: 440-6 surging
[Re: abomb]
#343148
06/10/09 11:19 AM
06/10/09 11:19 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
plugs....had the same issue recently with my 340... changed the plugs..it runs great...
why would it be the plugs? brand new ones at that? a surge like that...to me...sounds lean if anything. Did you let it warm up fully or did the mechanic that tuned it let it warm up?
Re: 440-6 surging
[Re: Mr.Yuck]
#343149
06/10/09 11:31 AM
06/10/09 11:31 AM
yup totally warmed, taken for a 15 mile test run and it ran perfect. Started it this morning and it runs like crap. Called Sumit racing and they said it sounds like a internal vacuum leak?????. I went around and retightened all the nuts and bolts I could find and that changed nothing. If I change plugs what would you suggest.
Re: 440-6 surging
#343150
06/10/09 12:07 PM
06/10/09 12:07 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Do you have the distributor vacumn advance hooked up?
Al & Sheila
Re: 440-6 surging
[Re: 3twos]
#343151
06/10/09 12:18 PM
06/10/09 12:18 PM
yes but tried it both ways with no effect. just hooked a vacuum gauge to the intake and found I am pulling only 14" of vacuum, way down in the late ign. timing area. Prior to this I was pulling 19"
Re: 440-6 surging
[Re: Mr.Yuck]
#343153
06/10/09 12:38 PM
06/10/09 12:38 PM
sure it is not that but what we did yesterday was take the center carb apart and found that little o ring had been sucked out of its slot. Don't rmember what it was for but the carb guy said something about idle. Just talked to him and he thinks that o ring may have missed placed again.
Re: 440-6 surging
#343154
06/10/09 12:51 PM
06/10/09 12:51 PM
Mr.Yuck
Brookeville, Md
man I hope I don't have these issues... I was wanting to tweak mine Sunday but I ran out of gas after a few turns of the screw driver.... This weekend I'll get it done!
