Fuel Starvation #343078
06/10/09 10:01 AM
06/10/09 10:01 AM
North Riverside IL & Lowell IN
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I rarely post in the race forum but I think this the best place for this one...
I think I have a fuel starvation issue. I am running a carter M6903 with 3/8 fuel line through a 40 micron Russell in line filter from on my 500 inch stroker motor. Stock style fuel tank and pickup. Carb is a Quickfuel 830. It pulls fine up until about 4000 RPM and then it falls flat and bogs down completely until I let off the throttle.
Like I said I think it’s a fuel issue but maybe I’m wrong. If it is a fuel issue where do I start troubleshooting? How do I check a mechanical pump? I don’t have a fuel pressure gauge in the car, just one on the carb.
Ken
Re: Fuel Starvation [Re: GTXKen] #343079
06/10/09 10:04 AM
06/10/09 10:04 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Maybe hookup a temp fuel pressure line at the carb and put the gauge temp somewhere where you can see it when the car falls off?
Re: Fuel Starvation [Re: Challenger 1] #343080
06/10/09 10:09 AM
06/10/09 10:09 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I think a gauge is in order. If pressure falls off at 4k that dosen't mean its the fuel pump though right, just that its a fuel issue for sure?
Re: Fuel Starvation [Re: Challenger 1] #343081
06/10/09 10:09 AM
06/10/09 10:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
or if you have jets you can jet it up 2 or
3 jet sizes... if it does the same thing its more than
likely a supply issue
Re: Fuel Starvation [Re: MR_P_BODY] #343082
06/10/09 10:12 AM
06/10/09 10:12 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I have jets, I'm running 80s and 88s now and have a very minor bog at 1200 RPM. Are you saying jetting could be the issue?
Re: Fuel Starvation [Re: GTXKen] #343083
06/10/09 10:17 AM
06/10/09 10:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If its super lean it can be... if you can jet up and
not have it slow down its a supply thing(keep jetting up)
but at those jet sizes I dont think its the problem
Re: Fuel Starvation [Re: MR_P_BODY] #343084
06/10/09 10:17 AM
06/10/09 10:17 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Nappa sell flex gauge extentions, if you can find a spot to run the gauge where you can see it you can troubleshoot
Re: Fuel Starvation [Re: GTXKen] #343085
06/10/09 10:25 AM
06/10/09 10:25 AM
oregon
savoyracer Offline
savoyracer  Offline
oregon
Ken
Sure sounds like a fuel delivery problem. in my humble opinion everything you have is way to small for a 500 inch motor. you also might have another self-inflicted problem. If I were you, I would cut open my oil filter, and get a magnifying glass, and look in the pleats for brass. If it is there, time to put new bearings in it. Inadequate fuel delivery will cause a lean condition, which can take out bearings. not saying that it has happened yet, just saying you should look at it.
Re: Fuel Starvation [Re: GTXKen] #343086
06/10/09 10:27 AM
06/10/09 10:27 AM
I would think that the pump/line setup is your issue...A stock tank pickup with a 3/8" line and a mech pump pulling for fuel is asking alot to supply a 500cu.in. motor with a big carb. I would suggest a small electric pump (Like a Holley Blue) to push the fuel up to the mech pump. Install a regulator between the pumps to limit pressure to 6.5-7.0 lbs. This will insure constent fuel supply to the mech. pump..It is better to push the fuel rather than pull it...This will correct you problem and wiring the pump t the ignition will make it as stock as possible. (No switches to remember to turn on).I have seen this problem several times on street/strip cars...poppaj
Re: Fuel Starvation #343087
06/10/09 10:40 AM
06/10/09 10:40 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
A fuel pressure gauge is certainly in order. I'll stop by napa but I doubt mine will have what I need. The engine hasn't spent much time near 4000 so I don't expect I've done any harm.
The pump was suspect to me, any way to check a mechanical fuel pump or is it all or nothing?
I'll look into adding an electric pump at the tank. I heard the Holly blue was really loud, not that my exhaust won't be louder, any other good pumps?
Re: Fuel Starvation [Re: GTXKen] #343088
06/10/09 11:06 AM
06/10/09 11:06 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
A stock pump will not feed the hungry animal You can start by checking volume and pressure.But imho a fuel system upgrade is in order.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fuel Starvation [Re: hemi-itis] #343089
06/10/09 11:16 AM
06/10/09 11:16 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Just a thought, you may want to run it till the bog and shut down and pull the plugs, no money spent just a little time & go from there
Re: Fuel Starvation #343090
06/10/09 11:17 AM
06/10/09 11:17 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Sounds like this is where I will be headed, is my (all new) 3/8 line big enough? Holly wants the regulator by the carb. I assume that you suggest putting it between the pumps because my mechanical dosen't require a regulator and we don't want the electic fuel pump over powering the mechanical pump?
Re: Fuel Starvation [Re: GTXKen] #343091
06/10/09 12:45 PM
06/10/09 12:45 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I would advise you to throw the mechanical pump in the trash and replace it with a BG HR220 electric pump. This pump has a return style regulator which is needed for street driving. Using an electric to feed a mechanical is not a good idea. If the diaphram in the mechanical fails you could get fuel pumped directly into your motor. I don't use cam driven mechanical pumps for anything.
Re: Fuel Starvation #343092
06/10/09 01:03 PM
06/10/09 01:03 PM
mikemotorhead Offline
super street
super street
"you also might have another self-inflicted problem. If I were you, I would cut open my oil filter, and get a magnifying glass, and look in the pleats for brass. If it is there, time to put new bearings in it. Inadequate fuel delivery will cause a lean condition, which can take out bearings. not saying that it has happened yet, just saying you should look at it"
I assume you mean from missfires pounding the bearings??? If so I think it would take a lot of this to cause bearing failure!
Mike
Re: Fuel Starvation [Re: BobR] #343093
06/10/09 01:07 PM
06/10/09 01:07 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My guess is that its a pickup issue in the tank..
Few years back i was running low 11's with stock tank, mech pump and a 3/8 pickup..
I always left the tank full...one time i raced the car with 1/2 tank of gas in it and ran into same symptoms you are dealing with.(fuel sloshing around uncovered the pickup)
As others have stated, a cell and electric pump would solve your problems, but putting one of those sump/pickups in the bottom of your stock tank might well solve it as well....
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Fuel Starvation [Re: B3422W5] #343094
06/10/09 01:14 PM
06/10/09 01:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have a 1/2" pickup in stock tank with a mallory 140 pump and return style regulator. works great
-8an lines for both supply and return
Re: Fuel Starvation [Re: GTXKen] #343095
06/10/09 01:41 PM
06/10/09 01:41 PM
Exactly Ken, it will supply the mech pump with fuel without over running it. MSD makes a nice quiet inline pump that would be perfect for your car, and it is only $100. poppaj
Re: Fuel Starvation [Re: BobR] #343096
06/10/09 01:45 PM
06/10/09 01:45 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I can see where using both an electric and mechanical pump cpould be a problem. Before I jump to an electric fuel pump I need to remove any other issues there may be.
Re: Fuel Starvation [Re: GTXKen] #343097
06/10/09 01:57 PM
06/10/09 01:57 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Well, thanks for the replys
I really need to do some troubleshooting here before I throw money at more parts.
I have a checklist...
Pull the outlet side of the pump hose off and use the started to see if its putting out the fuel it should.
Pull the fuel pickup in the tank and see if there is anything clogging it or if its possible it could colapse.
Check the lines and connections for any obstructions or leaks.
Check the tank vent.
Check the stator to rotor clearence to see if its a spark issue at speed.
Check the powervalve size.
Make a run without an air cleaner (new)
Finally, get a fuel pressue gauge. This will take the better part of an evening, if anyone has any other ideas let me know.
Thanks again
