Re: How to mostly do a fresh 4 speed swap in an afterno
[Re: CokeBottleKid]
#34320
02/07/07 08:10 PM
02/07/07 08:10 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well as this was an OEM block,crank,bell,transmission,and OEM style clutch that measurement would not be an issue with most of the guys on this site.It will not effect the operation of this project. I knew that some of you guys with aftermarket parts and $3000.00 clutches and and old Pro-Stock cans with Lencos would pipe up with all the "racecar"measurements,we didn't measure the finger height with a dial indicator,balance our wheel with the plate,or check plate clearance with the pedal on the floor.These are all things that are needed with a "RACE" tranny installation.This was intended to be viewed as a guideline to install a transmission for a "STREET/STRIP" fun car. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: How to mostly do a fresh 4 speed swap in an afternoon
[Re: Fluffy]
#34322
02/07/07 08:26 PM
02/07/07 08:26 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
Looks like Bob was about to pull out his 9 and busta cap.
... nice shot, you caught me as I was making sure my lipstick was ok.
"EXCUSE ME WHILE I WHIP THIS OUT"
[Re: 10secGTX]
#34323
02/07/07 09:24 PM
02/07/07 09:24 PM
Posts: 1,539 Columbia Station, OH
MrBelvedere
Mr Zipper Lips
Mr Zipper Lips
It was a good time I had one the more important jobs you don't see much of me because I was the lift operator (very intense work)
You must have a sore finger
[Re: 10secGTX]
#34328
02/08/07 12:24 AM
02/08/07 12:24 AM
fourgearsavoy
Rittman Ohio
Was that "wisht"soup? Some veggies,spices,and broth and you wished you had some meat bow bow bow It was good stuff,nice flavor Gus
[Re: Fluffy]
#34330
02/08/07 07:41 PM
02/08/07 07:41 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
A twin sister. . I bet nobody EVER knew 'bout that..
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: sunroofgtx]
#34332
02/08/07 08:12 PM
02/08/07 08:12 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Where did you buy the metal clutch rod ball swivel? I've seen them on E-bay from time to time. I would like to get rid of my grommets. Looks like a good time was had by all
