They are the same for many years. I think some of the ones that are different were only on vans and some c bodies, If I recall. A bodies such as a valiant dart or duster will be the best bet in locating one. Grab the steering column coupler to.
Since a power steering column is shorter than a manual steering column you will need an adapter
from firm feel. Unless you just happen to find a similar car to what you have with manual steering and change the column. I dont recall if the '64 polara would retain the same pitman arm or not when changing the box.
