Page 5 of 13 1 2 3 4 5 6 7 12 13
Re: VIN Stamping: MYTH or FACT [Re: 70440+6bbl] #342497
06/10/09 02:12 PM
06/10/09 02:12 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
How about this one- it is the 18 spline trans out of my '70 V-code 'Cuda and it has no VIN stamping. I have ownership history going back to the mid-'70's and so far, nobody remembers the tranny ever being changed out for another. The trans build date is Nov 5th '69., which also happens to be my cars SPD (B05).
The problem you have is that regardless of how far back it goes the ownership history is incomplete, as are the memories of past owners you do know. At this point I'd tend to go with "replacement" but it's POSSIBLE that it is the original and was never stamped, just not very likely, and without proof few will believe it when it comes selling time.
Re: VIN Stamping: MYTH or FACT [Re: ScottSmith_Harms] #342498
06/10/09 02:23 PM
06/10/09 02:23 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Understood, I just thought it was quite a coincedence considering the dates. Not too worried about the selling price if/when the time comes.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: VIN Stamping: MYTH or FACT [Re: 70440+6bbl] #342499
06/10/09 02:58 PM
06/10/09 02:58 PM
SE Pa.
LimeliteAero Offline
SE Pa.
regarding the issue of trans vs engine with the numbers not be in the same alignment.
Isnt it possible the production line worker saw the mis-alignment and corrected it before stamping the matching item?
Re: VIN Stamping: MYTH or FACT [Re: TONY_DAGOSTINO] #342500
06/10/09 03:00 PM
06/10/09 03:00 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Tony, could someone buy a complete 440 HP engine in 1969?
Re: VIN Stamping: MYTH or FACT [Re: LimeliteAero] #342501
06/10/09 03:03 PM
06/10/09 03:03 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
That would imply some kind of "Quality Control".... ........ah, I'm think that may not have happened back then
Re: VIN Stamping: MYTH or FACT [Re: LimeliteAero] #342502
06/10/09 03:07 PM
06/10/09 03:07 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
yes an assembly line worker could have corrected a jumbled stamp, but i wouldnt think that to be likely
many things are possible,
and there are usually exceptions to the way things were done
ive only seen short or long blocks being warrentied,
only shortblocks show up in the parts book (at least the 1969 book)
i honestly dont know if a complete motor was available
i do have a flier from chrysler to a dealer from when the 1965 hemi engines were being sold off as complete units
but i think that was only because it was a race type motor,
not sure if otherwise
do you have pics of the tag on the motor?
Re: VIN Stamping: MYTH or FACT [Re: TONY_DAGOSTINO] #342503
06/10/09 03:11 PM
06/10/09 03:11 PM
DELAWARE
DELAWARE
in galens book #II he does list engine assy numbers,
the last 3 digits are found on lynch rd fender tags
in 69 he only lists the last 3 digits
but the full 7 digit part # for 1970-1971
then goes back to the 3 digit #s for 72-74
Re: VIN Stamping: MYTH or FACT [Re: A12] #342504
06/10/09 03:59 PM
06/10/09 03:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
and here's an "over the counter" '69 440 HP (2) engine, unstamped with the Bridgeport milling marks and it appears they missed the front edge of the pad during that milling.....the engine assembly date/code pad is stamped E440 3 28 HP 2 with a upside down "C" and a sideways "B"
MikeR
which end ???
edit ... I see tony touched on that
Re: VIN Stamping: MYTH or FACT [Re: west] #342505
06/11/09 01:50 AM
06/11/09 01:50 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Are there any detials left out? Does the date match the car.
Re: VIN Stamping: MYTH or FACT [Re: BulletBob] #342506
06/11/09 09:24 PM
06/11/09 09:24 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
So in 1971 on Cudas and Challengers Chrysler used a machine to roll the numbers onto the motor and transmission. Does anyone have any picturs of such a piece of machinery. I ask this because I was wondering just what the machine looked like to be able to be held against the motor and later the transmission so the rolled press would happen. If there was not a way to hold this machine against the motor and then the transmission then there would be not enough pressure to complete the stamping.
I have seen the stamp or punch that was used via changing the numbers and hitting the punch with a hammer. I can see by going to the 1B###### you would only have to have one punch in 1971. Other years that use complete VINS would have to have many punches or have the ability to change not only the numbers but the letter. Example RS,RM,WS,WM
1971 HEMI E BODY REGISTRY
Re: VIN Stamping: MYTH or FACT [Re: hemicar1971] #342507
06/11/09 09:30 PM
06/11/09 09:30 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
It was a pneumatic hammer kind of punch. I found a pic of one but think it is on my machine at work. Cha-chunk, Cha-chunk
Re: VIN Stamping: MYTH or FACT [Re: FJ5_Fish] #342508
06/11/09 09:59 PM
06/11/09 09:59 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Here is one company but not the one I found a while ago.
web page
Re: VIN Stamping: MYTH or FACT [Re: FJ5_Fish] #342509
06/12/09 05:09 PM
06/12/09 05:09 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
If a block was replaced under warranty by the dealer, if it were stamped, would it be 'HAND' stamped? Also, would the warranty block have the upper pad by the waterpump stamped with an assy date from the factory, or did the dealer 'HAND' stamp that also? Were there any short/long blocks that were NOT stamped? Thanks.
Re: VIN Stamping: MYTH or FACT [Re: rayztoy] #342510
06/12/09 07:25 PM
06/12/09 07:25 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Some on this thread have said the dealership stamped warranty blocks.
I've been to over 100 dealerships over the years from 1975 into the 90's... in their stockrooms, upstairs, downstairs... all over.
A couple members here have been to more dealerships than me I'm sure.
In my travels I've yet to stumble onto anything that resembles any stamps in dealership inventory.
There is no part number that exists for such, so where did they come from.
Was there a bulletin telling the dealerships told to go to Napa or somewhere and buy stamps if needed.
Perhaps they were kept in the vault.
Re: VIN Stamping: MYTH or FACT [Re: mccannix] #342511
06/12/09 07:54 PM
06/12/09 07:54 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Hi Terry,
Thanks for chiming in. Would a warranty replacement block have the upper pad stamped by the water pump with the assy date? If so, would it have a warranty designation(ie:W or S)as an indicator?
Re: VIN Stamping: MYTH or FACT [Re: rayztoy] #342512
06/12/09 08:05 PM
06/12/09 08:05 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
It will have a number date (no year letter) and a "440" but it will either have S, W or WT on the ones I've seen.
Re: VIN Stamping: MYTH or FACT [Re: mccannix] #342513
06/12/09 08:12 PM
06/12/09 08:12 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Actually number and letter stamp sets are pretty common and I know many machanics and machine shop guys that have their own personal sets in their tool chests or tool boxes. We have four sets here alone at work and even a pneumatic engraver for motorcycle frames so I don't see why a dealerships service department wouldn't have a set or access to a set if it was required by State law to I.D. stamp something if replaced? Complete sets are only $60 - $200 on average so it's not out of reach for a good professional service shop IMO.
I know first hand that in California if for instance a replaced motorcycle engine is not stamped with the original engine number that is on the title the entire motorcycle is conficated and considered stolen even on a dirt bike. I had to explain this to a CHP officer that sometimes dirt bike engine cases are damaged beyond repair and replaced with even a used set but this didn't matter and it didn't match the title and what made it worse the kid that owned it was the nephew of a Sheriff he knew. So if it is required to restamp a replaced engine in a State then it better be done.
Individual or complete sets not too costly......
Re: VIN Stamping: MYTH or FACT [Re: A12] #342514
06/12/09 08:17 PM
06/12/09 08:17 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Here you go for $615 or a little more you can have one of these....
Re: VIN Stamping: MYTH or FACT [Re: FJ5_Fish] #342515
06/12/09 08:18 PM
06/12/09 08:18 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Would a block with the assy date stamped on the upper pad (ie: F440 HP 12 01), but with no stamp (ie:blank) on the bottom pad be a block from the parts dept(over the counter purchase), not warranty replacment?
Thanks Jimmy!
Re: VIN Stamping: MYTH or FACT [Re: rayztoy] #342516
06/12/09 08:32 PM
06/12/09 08:32 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Never seen one like that....how about original motor that was never smacked with the VIN? Seen that.
