FEA roll cage side impact (computer anaylsis)
#34217
02/03/07 01:08 PM
02/03/07 01:08 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Well guys I posted a while back about trying some different configurations of roll cages. I was specifically interested in what to do for the side/door bars. Because this was a street car, I really hate to put a "X" bar in, because of the difficulty's of getting in and out of it all the time. I kept debating between a single bar, and a "bolt in" X bar (same idea as a swing out bar, but in an X shape)
Finally, since I had it at my disposal, I decided to FEA the different types of configurations.
For those that don't know FEA stands for finite element analysis. It's basically a computer simulation of a crash.
What I did was a simplified model of a side impact with different bar configurations. I didn't get too crazy because these take 10 hours each with 5 computers working on it at the same time, just to run these simple models.
In addition to the single bar, and bolt in "X" bar, I decided to try a "T" style bar. The extra bar runs from the single bar, back down to the rocker bar.
I was amazed the difference that this "T" bar made!!!
The graph shows energy in the "Y" direction (up and down) and deflection in the "X" direction (left to right).
You can see the t and x bars are way better then just a single bar. The point where the curve flattens out is actually where the failure point is. They continue up slightly, just because it's still connected at the other end. But disregard anything above the point where the line gets flat. . .
The crash block was done as a constant energy. No weight, no inertia, no speed. Just a constant push, never slowed or stopped by the bars. That way you can see exactly when each one breaks, and how much each deflects.
So for example, if you take a crash of say magnitude 1.5 (in the up and down, energy is unit less in this case) the single bar (yellow) has about 70mm of deflection. If you stay on that 1.5 horizontal energy line, and move to the left. You can see the t bar only has about 40mm deflection for the same energy (crash).
And of course as you go up in energy (crash severity), the t-bar does much better.
The "x" bar in this case has a little bit more ultimate strength then the "t" bar, but not by much. Of course if you focused the crash down towards your knees a little, the x bar would excel vs. the t bar. But in all honesty, I'm more worried about being hit in the hip/pelvis area then I am the legs. You're a lot more likely to be seriously injured in this crash location.
The extra bar to make it a "t" doesn't interfere with getting in and out of the car. The weight increase is minimal, but as you can see as far as strength goes, it's a significant improvement.
Anyway. . pretty neat stuff. . .thought I'd share it with you guys.
Re: FEA roll cage side impact (computer anaylsis)
[Re: dizuster]
#34226
02/03/07 10:38 PM
02/03/07 10:38 PM
Posts: 3,505 DFW
mr_340
DFW
What caused the discontinuity (jog) in the X-bar curve? Would adding another tube at the T running back down to the main hoop to lower rocker tube improve the strength with additional triangulation? Certainly it would add extra weight, but I would be curious how much strength it would add?
Nice work. I'm suprised the T-bar was close to the X-brace, but the impact is in the middle of the tube in the X and at the intersection of the T.
Floyd Lippencott IV
[Re: mr_340]
#34228
02/03/07 11:08 PM
02/03/07 11:08 PM
dizuster
Oakland, MI
I think the "jog" in the x bar curve was from where the tube "kinked" from the edge of the crash block.
My guess is adding the second bar to the "t" probably wouldn't do much for the crash in this direction. I think the "t" bar as added takes care of the pull tension in that direction. However, from a frontal impact, I think that yes, adding that bar would help. This certainly wasn't a perfect model, the crash location really favors the "t" bar, but like I said before, it's probably the most likely area that you would be seriously hurt in a side impact.
[Re: mopardamo]
#34230
02/04/07 07:02 AM
02/04/07 07:02 AM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
OK, you have data for only 1/2 the reason behind having the side bars. The other is to stiffen the chassis. The X is much better as it ties the chassis in 2 different directions from the main hoop to the a-pillar bar (firewall bar).
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#34231
02/04/07 09:30 AM
02/04/07 09:30 AM
dizuster
Oakland, MI
Absolutely, the "X" bar is a big factor in stiffening the chassis. But for a street/strip car, the "X" bar is tough to stomach putting in for most people. I don't think anyone would argue that the "X" bar is a pain in the butt to get in and out of. I think a lot of people put in a single bar for that reason. I just wanted to share that adding one more bar, helps a ton in side impact.
For a true race car, the "X" configuration wins hands down for chassis stiffness.
MoparDanno I think you're talking about the rocker bar. It's in the "T" bar picture, it's just blue, not white/grey. It's one of the bars that the additional bar that makes it a "T" attaches to at one end.
