yes your right,
maybe this would be the time to change the camshaft.
camshaft now installed is a Bullet:
duration @.050 285 in 288 ex
lobe lift .4765 .4765
separation 112
timing events @ .050 325 72.5 78 30
duration @ .020 316 319 ex.
Gross lift .715 .715 ex
valve lash hot .026 .026
bullet recommended this one below which we have.
duration @ .050 287 in 295 ex
lobe lift .4765 in .4500 ex
separation 112
timing events .050 35.5 71.5 83.5 31.5
duration @ .020 319 329ex
gross lift .715 in .675 ex.
valve lash hot .020in .022 ex
degree 108
what would I expect if I changed to the 2nd one?
14.8 compression
Indy heads flow .426
1150 dominator
2 1/8 header 4 in collector
fuel 118.
a lot of numbers I'm not real familiar with they are both rollers
