Tapered Axle/Drum Puller Source #34197
01/30/07 08:27 AM
01/30/07 08:27 AM
Bitopia
jcc Online content OP
jcc  Online Content OP
Bitopia
Not sure if it is worth owning an early tapered axle/drum puller, is there a source to rent them? I have 4-5 rears that over the course of the next few years need to be pulled, and likely converted to flange axles. Any suggestions?
Re: Tapered Axle/Drum Puller Source [Re: jcc] #34198
01/30/07 08:34 AM
01/30/07 08:34 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Smoke wrench.
Re: Tapered Axle/Drum Puller Source [Re: jcc] #34199
01/30/07 11:41 AM
01/30/07 11:41 AM
Pahrump NV.
Doright Offline
Doright  Offline
Pahrump NV.
I have an actual puller for this sort of work I do not know off hand were you would find one today if you had to buy one but they are out there, try Snap On or Mack.
I would never try it with a torch though it wouldn't work. There on there too good.
I personally wouldn't go threw the hassle and expense of convert to flange axles either unless I was doing a shortened 4 link set up.
D Barnett
A&P mechanic,
FCC general radio Telephone operator.
Re: Tapered Axle/Drum Puller Source [Re: jcc] #34200
01/30/07 01:13 PM
01/30/07 01:13 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Cut the heads off the housing end studs with a torch. Use a punch to knock them into the brake cavity, then take a big hammer and smack the brake/axle assembly out of the housing.
Re: Tapered Axle/Drum Puller Source [Re: jcc] #34201
01/30/07 01:42 PM
01/30/07 01:42 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
NAPA
Re: Tapered Axle/Drum Puller Source [Re: DoctorDiff] #34202
01/30/07 03:37 PM
01/30/07 03:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've used DocDiff's method many times but if you want access to the brake parts you'll need the puller; many rental yards will have the heavy duty puller for rent.
Re: Tapered Axle/Drum Puller Source [Re: John_Kunkel] #34203
01/30/07 05:35 PM
01/30/07 05:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ebay.I bought my SnapOn one for like 40 bucks.Whitney has a cheap one but it will snap after a few uses.I mhope you are going to narrow those rears.If not they are a pain to use the late axles in.The bolt pattern is totally different on the housing end.Those drums also are worth a few $$$$ if they are good.Rocky
Chrysler Firepower
Re: Tapered Axle/Drum Puller Source [Re: jcc] #34204
01/31/07 05:17 PM
01/31/07 05:17 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
There's one on Ebay right now (where I got mine) with a bid of $35 and 4 days left. Go to tools and search for hub puller. I swapped my 64 Polara's axle for a 65 unit, but when I first got it I used a die grinder and opened up the center register just a little and that took care of the problem for me.
Jeff Adams 64 426 Polara
Re: Tapered Axle/Drum Puller Source [Re: Ledman_70] #34205
02/01/07 01:03 AM
02/01/07 01:03 AM
A Happy Place, A Happy Place, ...
57Plymouth Offline
57Plymouth  Offline
I read in an old old old book that you can loosen the nut on the axle end and drive the car in a few turns to break the drum loose. I've never tried it out of sheer fear. I used the tool pictured above.
Virtus Junxit Mors Non Separabit
