Re: Tapered Axle/Drum Puller Source
[Re: jcc]
#34199
01/30/07 11:41 AM
01/30/07 11:41 AM
Posts: 164 Pahrump NV.
Doright
Pahrump NV.
I have an actual puller for this sort of work I do not know off hand were you would find one today if you had to buy one but they are out there, try Snap On or Mack. I would never try it with a torch though it wouldn't work. There on there too good.
I personally wouldn't go threw the hassle and expense of convert to flange axles either unless I was doing a shortened 4 link set up.
D Barnett A&P mechanic, FCC general radio Telephone operator.
[Re: John_Kunkel]
#34203
01/30/07 05:35 PM
01/30/07 05:35 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Ebay.I bought my SnapOn one for like 40 bucks.Whitney has a cheap one but it will snap after a few uses.I mhope you are going to narrow those rears.If not they are a pain to use the late axles in.The bolt pattern is totally different on the housing end.Those drums also are worth a few $$$$ if they are good.Rocky
Chrysler Firepower
[Re: jcc]
#34204
01/31/07 05:17 PM
01/31/07 05:17 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
There's one on Ebay right now (where I got mine) with a bid of $35 and 4 days left. Go to tools and search for hub puller. I swapped my 64 Polara's axle for a 65 unit, but when I first got it I used a die grinder and opened up the center register just a little and that took care of the problem for me.
Jeff Adams
64 426 Polara
[Re: Ledman_70]
#34205
02/01/07 01:03 AM
02/01/07 01:03 AM
Posts: 2,597 A Happy Place, A Happy Place, ...
57Plymouth
I read in an old old old book that you can loosen the nut on the axle end and drive the car in a few turns to break the drum loose. I've never tried it out of sheer fear. I used the tool pictured above.
Virtus Junxit Mors Non Separabit
