Re: 1973 charger fire-wall relay box HELP!
[Re: ScatPakWarehouse]
#341676
06/08/09 09:06 PM
06/08/09 09:06 PM
Challenger 1
Cincinnati, Ohio
Working on a 73 charger on the fire-wall between the ecu & voltage reg. There's a box with 4 prongs coming out of the bottom with a plug & wires into the harness also has a reset switch on top, I never seen this before i was told only on a 73 has a 400ci if this is bad car won't start parts store has no clue, I can't even find in my books??? What is it & function any part #
Seat belt interlock bypass?
[Re: Challenger 1]
#341679
06/09/09 02:11 AM
06/09/09 02:11 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
it should be but... on a 73 ? that is 74 ( unless a VERY LATE 73 )
Thats to reset the interlock function in case of fail. On interlocked cars, you need to fasten your seatbelt before start the engine. If you don't do it, Starter motor won't crank
more info ( and a video ): http://wichargerguy.proboards.com/index....amp;page=1#7583
PN... I have TWO PN according with Car built date: Up aprox to 9-24-73...3746723 after aprox 9-24-73...3746901
now, dunno if is just a change on number OR change on function
That button won't decide if you can start or not the engine, Thats just an Interlock control box decision. Reset button is in case of interlock control unit fail. And in case of fail on that button, you still can crank the engine jumping the starter relay LOL
