Re: Time for another Cal Trak Thread? (Long)
[Re: Keith Richards]
#341659
06/08/09 09:03 PM
06/08/09 09:03 PM
Posts: 1,880 USA
Ron Silva
USA
If your angles are good I would say replace the bushing in the rear of the trans and check the pinion. How much does the driveshat pull out of the trans? Also maybe try to let out of it when it is vibrating and see if it stops. That would tell you if it is rear pinion angle needing to rotate down.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#341661
06/08/09 10:26 PM
06/08/09 10:26 PM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
I have been thinking of checking out the rear bushing and thought I would see if anyone suggested that. To add to my initial post I would say that the acceleration noise is from the front u-joint or tail shaft and the initial deceleration noise is from the rear u-joint, and I believe I read some were when noise comes upon acceleration roll the pinion down a few degrees and when It comes on decel to roll the pinion up? I have tried rolling it up and down a little and the noises stay consistent so very well could be the rear bushing or maybe needs rear roller support for what (speed) the car is going?
[Re: Greg]
#341662
06/08/09 10:28 PM
06/08/09 10:28 PM
Keith Richards
Windsor ,Ca.
You might want to check the length of your driveshaft and has it ever been balanced. I would say it has to do with the clearance of the driveshaft in the trans tailhousing. When you change the preload it will change how much the driveshaft is in the tailhousing. If you know of a good chassis shop it may be good to get the car scaled with you in it to get the appropriate amount of preload and check the driveshaft length and maybe make sure it is in balance.
Every car is a little different so what works for an a body may not be the same with a B body. I always had good luck with the bars barely touching in my roadrunner. I was running an 8' converter and it was setup to flash between 5200-5,400 in my 499.
Yes , The driveshaft has been balanced twice so I am confident that is not the problem. The drive shaft is slid out 1" after bottomed out in the tranny.
[Re: Greg]
#341663
06/08/09 10:34 PM
06/08/09 10:34 PM
Posts: 6,295 U.S.
moparniac
U.S.
put a 2* shim out back....... whats your 60's BTW.... I went 10.6 @ 128.3 1.55 60 ft 1st time out with the caltracs.... -2 i believe on the tranny and -2 on the diff now.... no vibrations 3800lb car 2 flats preload on dr side and 1 flat preload on pass side... I have a dana 60 and no subber also
Mopar Performance
[Re: moparniac]
#341664
06/08/09 10:48 PM
06/08/09 10:48 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
Lets say your trans angle is 0* , than to get a -3* pinion angle you would rotate the rearend down -3*.
You say your trans angle is -3.5 , than you would have to rotate the rearend down -6.5* to get a -3*. Recheck your trans angle off your your crank pully.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: moparniac]
#341666
06/08/09 11:01 PM
06/08/09 11:01 PM
Keith Richards
Windsor ,Ca.
60's are 1.520 to 1.54 depending on track conditions, 4.10 gear, 30x9 Hoosier drag radial
Car is usually in the low 10.50's @ 127 if no wind and has touched 10.47 - 48 a few times. This is a 500" pump gas motor with full exhaust out the back.
[Re: caper]
#341668
06/08/09 11:04 PM
06/08/09 11:04 PM
Keith Richards
Windsor ,Ca.
Calvert wants -2 to -4 total (tranny and rear combined) So to me tranny at -3.5* and rear at 0* is a total -3.5 ?
[Re: Islandcuda]
#341669
06/08/09 11:08 PM
06/08/09 11:08 PM
Keith Richards
Windsor ,Ca.
You say your sheild is already hitting the floor, could that be the vibration spot?
I have had that thought as well, hope that is it as I probably have close to 100 runs playing with this thing, trying to figure it out and so far it hasn't gone BOOM and the u-joint all feel tight and rollers look good. Maybe I should try and lower the tranny another .5 degree and give it some clearance.
#341670
06/08/09 11:35 PM
06/08/09 11:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On the drive shaft I've always used 3/4" max for the amount of movement back from bottom... the farther you go rearward the more movement it will have... specially if you have a worn tail shaft bushing
[Re: formula S]
#341671
06/09/09 01:18 AM
06/09/09 01:18 AM
Keith Richards
Windsor ,Ca.
Check out this link it might help you out http://www.markwilliams.com/driveshafttech.aspx
Ok, just got back in from the garage with digital level in hand and here is where the car is at now:
trans/ engine -3.5* (I always measure from balancer)- drive shaft arrow down 0.5* arrow up (driveshaft is .5* down from meeting pinion) - rear is 0.5* pinion down. So to me that is a total of -4* combined trans and rear as Calvert recommends 2 - 4* for Mopars with there products.
That is with a 1/2 turn of preload, If I went to nuetral the rear would be at 0* .
Sound right? Now looking at Mark Williams sight above they are saying I need to roll the pinion up to +3
#341672
06/09/09 12:50 PM
06/09/09 12:50 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
This explains it good: http://www.rosslertrans.com/Pinion%20Angle.htmYour looking for the angle of the tranny shaft and the rear pinion to be near zero upon hard launch. Since the tranny is stationary then the rear pinion will have to do all the work. If tranny is at -3.5 then the rear would be at 0 degrees resting assuming the rear rotates up 3.5 degrees on exceleration that would give you 0 degrees alignment with the tranny.
#341674
06/13/09 05:10 PM
06/13/09 05:10 PM
Posts: 718 Vallejo California
T748
super street
super street
Vallejo California
You might want to check your spring pads if you havn't lately. The Cal Tracs crushed my stock style pads from flat to semi-circles in a season. Between that and trying the air gap trick it took out a bit too much pinion angle. With a set of re-enforced spring pads from these guys- http://www.ruffstuffspecialties.com/catalog/d60-88-9-spring-perch-p-253.html4 degrees of pinion angle, I'm not feeling any drive line funkyness. Also went back to half a turn preload on the passenger side and just touching on the drivers. -Tom.
