69 single four barrel air grabber base #34162
01/21/07 10:09 AM
01/21/07 10:09 AM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
Does any one know how to tell the difference between a 440 oval air grabber base and a 383 unit?
thanks
Re: 69 single four barrel air grabber base [Re: torkrules] #34163
01/21/07 02:06 PM
01/21/07 02:06 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
if you lay it on a flat surface and the round part that sits on the carb is original and uncut
383, the whole unit will sit slightly off the flat surface
440, the unit will touch the flat surface
the 440 unoit is lower due to the 440 being slightly taller than a 383
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 69 single four barrel air grabber base [Re: AZ_A12_BEE] #34164
01/21/07 07:34 PM
01/21/07 07:34 PM
I'm neurotic
I'm neurotic
Thanks for the information. I'll have a look!
Re: 69 single four barrel air grabber base [Re: torkrules] #34165
01/22/07 01:27 PM
01/22/07 01:27 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
The difference in height of the necks is about 3/8"....
383 base
Butch
Re: 69 single four barrel air grabber base [Re: CHRYCOFAN] #34166
01/22/07 01:28 PM
01/22/07 01:28 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
440 base
Butch
Re: 69 single four barrel air grabber base [Re: torkrules] #34167
01/22/07 05:54 PM
01/22/07 05:54 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
For the number of times this comes up, we should get this into the tech archives with those two pictures. Just my
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
