I got to see a lot of real fast cars 200 ++ and close to 300 mph jet car
the 63 {3500 lb car} ran 9.914 best et
best light .001 gave me tenth best in eliminations.
best mph 134.
I had to short shift the car until gears are changed so should see better..
shifting @ 6300 peak should be 6800
moved launch up to 4700
went thought finish @ 6850 rpm
jets up to 99 from 96's in the 1150 Dominator
the top end miss is GONE
60 ft times were mostly in the 1.37's
made some mistakes
all in learning
have 18 passes on the car in the 1/4 mile.
won a round then the car broke.
come to fine out the head gaskets should have had sealer around the water passages which we didn't do.
got h2o in the oil so the party was over.
have new gaskets and a water pump on the way, looks like no other parts were damage.
I caught it before it got real hot for to long.
the top of the pistons look good.
heads are going to get checked at the machine shop.
Thank for all the help last week
