Re: Fuel starvation problem
[Re: R/T1968R/T]
#341254
06/08/09 12:47 PM
06/08/09 12:47 PM
Posts: 309 Dearborn, Michigan
gtxncuda
Dearborn, Michigan
I had a similar issue with intermittant fuel pressure and no starts on my GTX (but don't have a FP gauge). Ended up being the actuator rod being worn down on the cam end. A trip to Mancini, a half hour and $12 bucks later... problem solved! Good luck!
1971 Cuda 340 auto 2013 Mustang Boss 302 L/S 1969 Road Runner RM21 440 4 speed
[Re: R/T1968R/T]
#341258
06/09/09 10:35 AM
06/09/09 10:35 AM
RapidRobert
As said I would check your fuel pump pushrod if it has any kind of miles on it & there was a run of bad ones
