Milling and big block cylinder heads... #341061
06/07/09 11:17 PM
06/07/09 11:17 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
OK, here's the scenario...
I have a pair of heads off an engine and I want to cut them .030".... BUT the surface of the heads look odd to me, and I am wondering if they have ALREADY been cut....
They are 1974 440 heads, 3769902 heads. Can I measure from the base of where the lower head bolts go - down to the deck surface, or ...? How can I tell if they have been milled or not?
Anybody got any methods??
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341062
06/07/09 11:31 PM
06/07/09 11:31 PM
IA
landon1 Offline
landon1  Offline
IA
i heard 1" height were lower head bolts go....but when you're talking thousandths of an inch, idk how accurate that can be - best bet is to CC them
'71 Satellite Sebring 440
Re: Milling and big block cylinder heads... [Re: landon1] #341063
06/07/09 11:35 PM
06/07/09 11:35 PM
Canada
Canada
I think they are SUPPOSED to be rated at 81.5 cc but most were 85-86cc that I have actually tested, so I'm not sure CCing them would be accurate either?!?
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: landon1] #341064
06/07/09 11:39 PM
06/07/09 11:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
this is correct very close , plus minus .005ish to 1.000 ..
902 is an open chamber head ??? , 81.5 cc ??
Re: Milling and big block cylinder heads... [Re: JohnRR] #341065
06/07/09 11:42 PM
06/07/09 11:42 PM
IA
landon1 Offline
landon1  Offline
IA
i think that the 906, 346, 452 heads are all about 86-88 CCs aren't they? i had never heard 81.5
Re: Milling and big block cylinder heads... [Re: landon1] #341066
06/07/09 11:43 PM
06/07/09 11:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
90-92
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341067
06/07/09 11:44 PM
06/07/09 11:44 PM
the factory milled head decks with a straight cutter & MOST machine shops use a circular milling machine so if the marks are circular you know for sure that it's been cut on.
Re: Milling and big block cylinder heads... [Re: RapidRobert] #341068
06/07/09 11:45 PM
06/07/09 11:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A straight cutter ???
Re: Milling and big block cylinder heads... [Re: JohnRR] #341069
06/07/09 11:45 PM
06/07/09 11:45 PM
IA
landon1 Offline
landon1  Offline
IA
90-92
maybe i got my numbers because that's what mine are supposed to be since they were milled
Re: Milling and big block cylinder heads... [Re: JohnRR] #341070
06/07/09 11:52 PM
06/07/09 11:52 PM
Not sure about the exact name of the machine but it does leave straight milling marks on the deck surface
Re: Milling and big block cylinder heads... [Re: landon1] #341071
06/07/09 11:57 PM
06/07/09 11:57 PM
Canada
Canada
I went and checked a half dozen sites, all were 81.5 cc for the 902 heads....
3769902 1974 440 400 2.08" 1.74" 81.5cc
http://www.motortopia.com/forums/viewtop.../tp/1#post_3902
http://bionicdodge.com/bionic/index.php?action=printpage;topic=5657.0
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341072
06/07/09 11:59 PM
06/07/09 11:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
they list the 906 at 79.5cc , thats the NHRA blueprint spec . measure what you ACTUALLY have , do not believe everything you read ...
Re: Milling and big block cylinder heads... [Re: RapidRobert] #341073
06/08/09 12:00 AM
06/08/09 12:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW whether they have been milled or not is less important than the final chamber volume, measure them now & cut them to obtain the volume you need to get the C/R you want...
BTW .0062 off the deck = 1cc & for every .010 off the deck cut the intake surface of the head .0123
And BTW John is absolutely right.. Blueprint spec isn't even close to what Mopar really supplied.. 88cc happened allot less than 91-92cc
Re: Milling and big block cylinder heads... [Re: JohnRR] #341074
06/08/09 12:03 AM
06/08/09 12:03 AM
Canada
Canada
Thanks for the great response!
I guess you missed where I said they were RATED at 81.5cc but most I have actually TESTED were 85-86cc....?
Is there anybody HELPFUL on MoParts left anymore?
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341075
06/08/09 12:05 AM
06/08/09 12:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
maybe you missed where i agreed they should be 1.000 , back away from the keyborad , put down the crackpipe and go measure them , they have probably been cut .
any more silly staements ?
Re: Milling and big block cylinder heads... [Re: JohnRR] #341076
06/08/09 12:05 AM
06/08/09 12:05 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
90-92
Re: Milling and big block cylinder heads... [Re: 1_WILD_RT] #341077
06/08/09 12:06 AM
06/08/09 12:06 AM
Canada
Canada
Therein lies a small problem and why I posted this....
Who knows if the heads have been shaved... they look like they have, but the intake surfaces look stock. If they were cut already the .0123 certainly hasn't been taken off. I just wonder if there is a way to determine what the factory height off some point on the head to the deck surface or something, so I have SOME kind of bearing...
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: JohnRR] #341078
06/08/09 12:06 AM
06/08/09 12:06 AM
Canada
Canada
any more stupid questions ?
Yup.
Why are you here?
Now GET OUT!
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: JohnRR] #341079
06/08/09 12:08 AM
06/08/09 12:08 AM
Canada
Canada
You can't even EDIT meanly!
CrAzYMoPaRGuY
Re: Milling and big block cylinder heads... [Re: CrAzYMoPaRGuY] #341080
06/08/09 12:08 AM
06/08/09 12:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It is not surprising to see the intake side not cut , that cost EXTRA over the deck mill .
