Slick Tubes ? #340404
06/07/09 09:32 AM
06/07/09 09:32 AM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
Ok, been running tubes forever, what's everyones opinion on running tubeless. I'm thinking of experimenting.
Re: Slick Tubes ? [Re: 540dust] #340405
06/07/09 09:43 AM
06/07/09 09:43 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I run tubeless until the side walls start to leak, then put in the tubes. I don't know why I do it that way as they always eventually leak and it cost me to have them broke down to put the tubes in. I haven't seen any difference in et from with or with out.
Re: Slick Tubes ? [Re: 540dust] #340406
06/07/09 09:51 AM
06/07/09 09:51 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i know that alot of people have an opinion on this.
this perspective comes from experience with small tires ..or a class that required a small tire
26x10x15..
i surmise these issues still apply to bigger tires..but bigger tires have more traction available.(to a certain degree based on the size of the contact patch and lbs per square inch applied to this contact patch..as the contact patch size goes up ..the load in lbs per sq inch goes down)
tubes can be more complicated ..when it comes to installing and removeing tires..
but i have found..tubes help regulate or stablise tire pressures...they are more resistant to drastic temp or quick temp changes..this can help keep tire pressures consistantcy.
tubes can help support sidewalls..which can extend the life of the tire. or help a tire with a lot of passes... usually slicks go away even though there is plenty of wear indicator left..
the abuse on the side walls and heat cycles drastically effect slick life.
a tube can act like a shock absorber and tame down a hard hit..again allowing the tire to stay gripped.
a tube can add mass = inertia to a tire so it will grow at speed ..effectively gaining you some gear on the top end..
on a tall sidewall aspect ratio a tube can help keep the car straight on the big end..(less wandering)
a tube will also help keep the tires contact patch from foldiing over..it holds the sidewalls out and the tread patch flat..
all of this helps traction and even more so consistant traction..
there are some maintainence issues like the afformentiond..mounting process..
stem to rim fitment..
shifting or bunching of the innertube which requires ...sevice and or tire rotation..
then there is added cost's
and added weight..
if you have a decent size tire..for the cars performance most of these issues will seam irrelivant.
but if your running a smaller (class restrictions)slick...and not running tubes...
you might find some improvements improvements with tubes..
your pic looks like you got a healthy tire under there.
you may find with out a tube you see NO loss of traction....and the savings of weight improves your et...?
only one way to find out.
fwiw
cheapst..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Slick Tubes ? [Re: cheapstreetdustr] #340407
06/07/09 03:52 PM
06/07/09 03:52 PM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
Cheapstreet, that makes sense but one point that seems unclear is that the tube would be a shock absorber to soften the hit, I would assume a more flexable sidewall would soften the hit to the track more than a stiffer one. I would think that tubes would effectively stiffen the sidewall. I have always ran tubes and have never tried without.
How many here are not running tubes ??
Re: Slick Tubes ? [Re: 540dust] #340408
06/07/09 05:43 PM
06/07/09 05:43 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I run a 14x32x15 no tubes here
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Slick Tubes ? [Re: dusturbd340W5] #340409
06/07/09 06:02 PM
06/07/09 06:02 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
29X11 no tubes but run pure nitrogen to keep the pressure more even with temp.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Slick Tubes ? [Re: 540dust] #340410
06/07/09 06:42 PM
06/07/09 06:42 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I always have run tubes and have gone thru several sets of tires using the same tubes. Can't stand finding flat slicks after the car has sat for a while. Dish soap treatment has never worked for me. Just use baby powder when you install tubes and screw them to the rims.
The little old lady from Pasadena is back!
Re: Slick Tubes ? [Re: 540dust] #340411
06/07/09 06:54 PM
06/07/09 06:54 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
...i switched to NO tubes over the winter and i have seen no et gain or 60' gain.. i have had to lower the air pressure 1 lb. to get the car to 60 the same as it did last year with the tubes...i thought along the same lines as you about the tube helping with sidewall stiffness but i can't say that i'm noticing any diff sidewall wadding than i had with the tubes at launch...i thought with heavy car like mine and leaving off the transbrake that i surely needed to run tubes,but after talking to a few other racers on other websites i decided to try no tubes to start the season. I see no difference....
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Slick Tubes ? [Re: 540dust] #340412
06/07/09 11:39 PM
06/07/09 11:39 PM
the tube is a seperate structure so it absorbs some of the flex and or energy..
it also disperse's it..
which can be very effective..and still be plyable..
i wouldnt say it stiffens the tire side wall
but it does support it..
sort of like multiple strands being stronger than one single stand..
or pages in a phone book ..they are still flexable as a whole..but stonger than a single page..
fwiw..I dont have an opinon on weather or not to use them..
only what the factors, involved are..
chepast
[image][/image]
Re: Slick Tubes ? [Re: cheapstreetdustr] #340413
06/07/09 11:47 PM
06/07/09 11:47 PM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
Well, ok Cheapstreet, thanks for the thoughts. I guess we'll see in a week or two, I'm going to try it since I never have and just see the results. A drop in ET will be a plus but not at the risk of inconsistancy, if that is the case, the tubes will go back in quickly.
Re: Slick Tubes ? [Re: 540dust] #340414
06/08/09 12:49 AM
06/08/09 12:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran Hoosier QTP tires of 29 x 11.5 and now the radial slicks at 30 x 9 and I do not run tubes in either. They hold good pressure as it does not even drop thru the winter. The M/T 28 x 9 slicks I had would leak all the air in a few hrs so I ran tubes in them. Ron
Re: Slick Tubes ? [Re: 383man] #340415
06/08/09 12:30 PM
06/08/09 12:30 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I don't know too many racers that still use tubes. I haven't used a tube in a slick for 20 years. We are harder on tires in our Outlaw 10.5 car than anyone I know and we feel tubes are completely unnecessary.
