Re: BB rocker shafts question...... [Re: RapidRobert] #340200
06/08/09 11:22 AM
06/08/09 11:22 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Well, cool. I'll rag it up, so not to get crap in it.....drive the freeze plug in further and take what I need off & call it good. With my pedestal grinder.
Moparlee
Re: BB rocker shafts question...... [Re: RapidRobert] #340201
06/22/09 09:32 AM
06/22/09 09:32 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Does anybody now where I can get the threaded plugs for the ends of the shafts?
Thanks.
Moparlee
Re: BB rocker shafts question...... [Re: Robbins] #340202
06/22/09 07:46 PM
06/22/09 07:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pipe plug from the hardware store. You'll need to tap the end.
Re: BB rocker shafts question...... [Re: Robbins] #340203
06/22/09 08:20 PM
06/22/09 08:20 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
I bought some 3.9 rocker shafts sealed power from rockauto and all the holes were drilled wrong. time on the drill press.
Re: BB rocker shafts question...... [Re: Rollin Hand] #340204
06/23/09 05:27 PM
06/23/09 05:27 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
440 Source has them for the stock shafts. I looked everyware and had no luck finding them locally.
Re: BB rocker shafts question...... [Re: THESHAKERPROJECT] #340205
09/13/09 02:23 PM
09/13/09 02:23 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I ended up taking them and having them turned on a layth (spelling). The step that the freeze plug goes up against was not deep enough once it was turned down to where it needed to be so I had him fix that too. I thought I got back to this thread. I found those freeze plugs.....I'm almost thinking that I got a Dorman part #. If anybody needs the part number I'll get it for you.
The part number for the shallow cups(39/64th)Dorman part is 555-067
Moparlee
