BILL EVANS WIRING HARNESSES ???? #340119
06/06/09 11:46 PM
06/06/09 11:46 PM
Anonymous OP
Anonymous OP
Has anyone had engine harnesses made up by Bill Evans,out of Erie,Pennsylvania? I heard he does quality work,and does custom pieces,like MSD control boxes. Any opinions,good or bad,are appreciated! Randy Borawski
Re: BILL EVANS WIRING HARNESSES ???? #340120
06/07/09 12:08 AM
06/07/09 12:08 AM
Gateway to the West.
hemi_harvester Offline
YES I have bought 3 harnesses from him, all worked perfect and no issues. I can't say if they are all 100% concorse correct because I don't know. But they work as intended and I highly recommend,
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: BILL EVANS WIRING HARNESSES ???? [Re: hemi_harvester] #340121
06/07/09 12:21 AM
06/07/09 12:21 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I was happy with mine as well. Plus they are a decent price to boot.
Re: BILL EVANS WIRING HARNESSES ???? [Re: moparmojo] #340122
06/07/09 12:28 AM
06/07/09 12:28 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have some for my demon, not installed yet but they do look nice.
Re: BILL EVANS WIRING HARNESSES ???? [Re: chrisf] #340123
06/07/09 06:23 AM
06/07/09 06:23 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Yes, yes and yes.
Bill has always treated me right and makes a great product.
Whenever I get an engine harness from him, I have him extend and hide the wires for the ECU under the battery tray.
http://evanswiring.tripod.com
Re: BILL EVANS WIRING HARNESSES ???? #340124
06/07/09 06:45 AM
06/07/09 06:45 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
One more for Evans.........
Makes a great product and as mentioned will customize a bit as well!
I've always liked what I've got from them, highly recommend
Re: BILL EVANS WIRING HARNESSES ???? [Re: idrivevintage] #340125
06/07/09 07:01 AM
06/07/09 07:01 AM
Anonymous OP
Anonymous OP
my A12 superbee harness wire from the bulkhead wasnt crimped properly in one of the wires and it caused my car not to start. it was in the engine compartment side, after going over all the wires we found the culprit.
i emailed bil evans and he said send the harness back, i was hoping for him to say ill send you another one out and then send me back the defective one after you get the new one installed.
oh BTW, its not close to concourse correct.
the ones from Frank Badalson and yearone are better concourse correct.
Re: BILL EVANS WIRING HARNESSES ???? #340126
06/07/09 10:46 AM
06/07/09 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
concourse and CORRECT should NEVER be used in the same sentence
Re: BILL EVANS WIRING HARNESSES ???? [Re: JohnRR] #340127
06/07/09 11:10 AM
06/07/09 11:10 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
care to elaborate
Re: BILL EVANS WIRING HARNESSES ???? [Re: gtx6970] #340128
06/07/09 11:29 AM
06/07/09 11:29 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you want absalute OE correct you'll need original harnesses (NOS or mint used, etc.). As far as reproductions, M&H (sold exclusively through Year One) produces the best I've seen concerning correct original colors and details, but none of them are an exact match to original.
Re: BILL EVANS WIRING HARNESSES ???? [Re: ScottSmith_Harms] #340129
06/07/09 12:01 PM
06/07/09 12:01 PM
Anonymous OP
Anonymous OP
Thanks for ALL the input fellas! Concourse correct is NOT an issue on my concourse-incorrect GTX! Sounds like the mojority of you were/are satisfied with his product. I will be ordering my harnesses today! Thanks again! RandyB
Re: BILL EVANS WIRING HARNESSES ???? #340130
06/07/09 12:45 PM
06/07/09 12:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Randy I did run into the same issue as superstockracer , had a connector come off from a bad crimp , called and had them send me another connector instead of expecting a complete replacement harness before returning the other
Re: BILL EVANS WIRING HARNESSES ???? [Re: JohnRR] #340131
06/07/09 01:01 PM
06/07/09 01:01 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I also had 3 crimps come loose at the bulkhead connector but I got one last week for another car that looks better. I would chect it at the bulkhead side befor you install it. He replaced the bad one I got from him with a new one and that one has been good for the last 5 years.
Re: BILL EVANS WIRING HARNESSES ???? [Re: THESHAKERPROJECT] #340132
06/07/09 02:16 PM
06/07/09 02:16 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Set one on fire the other day, guess the E-Body I was working on has a shorted amp guage which caused the original harness to burn. I am going with M&H this time, the Evans harness had issues with proper wire lengths at the coil which caused other issues with connections.
JB Rhinehart, Realist
A-Body's RULE!
Re: BILL EVANS WIRING HARNESSES ???? [Re: Rhinodart] #340133
06/08/09 01:06 AM
06/08/09 01:06 AM
California
70SportSatellite Offline
super street
super street
California
Sent a Bill Evans to Mike at M & H. Let's just say I was lucky I didn't use it. Go with M & H.
Re: BILL EVANS WIRING HARNESSES ???? [Re: 70SportSatellite] #340134
06/08/09 06:42 AM
06/08/09 06:42 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Did you expect him to tell you otherwise ?
Re: BILL EVANS WIRING HARNESSES ???? [Re: AdamR] #340135
06/08/09 10:29 AM
06/08/09 10:29 AM
SE Pa.
LimeliteAero Offline
SE Pa.
the Evans harnesses have been around for a long time, I would say they cant be too bad or word would be out to avoid them at all cost in which case they would be gone.
Maybe not the best game in town but I think theres a case of piling on going on now.
Re: BILL EVANS WIRING HARNESSES ???? [Re: LimeliteAero] #340136
06/08/09 12:24 PM
06/08/09 12:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you just join Moparts this morning ?
Re: BILL EVANS WIRING HARNESSES ???? [Re: JohnRR] #340137
06/08/09 07:33 PM
06/08/09 07:33 PM
Anonymous OP
Anonymous OP
Still haven't ordered my harnesses yet!! I don't like,or feel comfortable,with a product that gets such mixed reviews! I guess I'll have to do a little more research! RandyB
Re: BILL EVANS WIRING HARNESSES ???? #340138
06/08/09 07:42 PM
06/08/09 07:42 PM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
i had a evans harness that had 4 connectors fall out of the bulkhead. it was a piece of junk.
i called him and his attitude wasnt good, hes not much of a people person, his attitude at carlisle is i cant be bothered with no personality.
i got mine from yearone and with the 15% discount it wasnt bad.
