3/8" return line, how much will it support ? #34007
01/16/07 02:46 AM
01/16/07 02:46 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
How much power will a 3/8" return line support in a low pressure carburetor application ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 3/8" return line, how much will it support ? [Re: AlexP] #34008
01/16/07 04:43 AM
01/16/07 04:43 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
hmmmm if your pump supplies enough fuel for 2000HP and your supply line supports 2000HP and your motor needs 2000HP... your return line can be gone .
Course once you let off the throttle you'll be swimming in fuel .
Point is there isn't really a direct correlation between return line size and HP.... It's always nice to have more though....
Re: 3/8" return line, how much will it support ? [Re: CokeBottleKid] #34009
01/16/07 07:42 AM
01/16/07 07:42 AM
Q
Quicktree Offline
Quicktree  Offline
Q
the return line on a bypass system should be bigger than the feed. at least a -10.
Re: 3/8" return line, how much will it support ? [Re: Quicktree] #34010
01/16/07 08:18 AM
01/16/07 08:18 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I've seen people saying the return should be bigger, that's not the way Product Engineering recomends building a fuel system. I run -10 from the pump to the regulator and -8 as a return.
Re: 3/8" return line, how much will it support ? [Re: Bigcube] #34011
01/16/07 10:46 AM
01/16/07 10:46 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'll second the "it should be bigger" deal. Well, at least AS BIG as the feed. But truthfully, that is so when you are looking at your fuel pressure, it is a true reading. Pressure is resistance to flow. So you will always show more pressure than what you really have if the return is smaller. Think of it as a "leaking deadhead" system..lol. In a true return style system, your pumps are so big becuase they have to overcome the G forces of the fuel sloshing backwards too. I dont know of too many engines at full throttle that can ingest the full output of 70 gph of even the small cheapo pumps.
Re: 3/8" return line, how much will it support ? [Re: Bigcube] #34012
01/16/07 11:12 AM
01/16/07 11:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
pm RobbMc and ask him he's an engineer that designs fuel systems and such. this is some stuff he wrote a while back.
Whenever you run a low pressure pump and no regulator, there will be a pressure drop during acelleration. Even if you ran a 250 pump and somehow set the pressure of the pump low enough to run without a regulator, you would get a pressure drop because the pump must be at the back of the car and the carb is at the front and there is a pressure drop between the two as the flow increases. The pump is still putting out 6.5 psi (assuming the pump is big enough) even when the pressure at the carb has dropped to 3 psi. To make it work right, you must run a regulator.
Having said all of that, the 110 pump ain't gonna do it, even if you add a regulator. The 110 will support about 550-600 hp when used with a return regulator (it cannot be used with a dead-head because the pump internal bypass won't adjust high enough). But if you are in the 750 hp range, you are going to need to use a 140 pump and a return regulator or a 250 pump and either type of regulator (although a return regulator is always better).
If I were you, this is what I would do: Run -10 lines from the tank to a large filter and then to a 250 pump. The -10 lines on the vacuum side of the pump will prevent cavitation, especially on hot days. Then run -8 lines from the pump up to the return regulator mounted in the engine compartment. (The feed line can be smaller because it is under pressure). Use the large Mallory return regulator, not the little 4309. Then run -6 or -8 up to the carbs. Use the -10 line you are now using as a supply line as the return line from the regulator back to the tank. Return regulators are very sensitive to back pressure in the return line so you need a -10 line with a 250 pump.
After everything is hooked up, check the back pressure in the return line: With the engine off, turn on the pump. Remove the adjustment screw from the regulator so there is no load on the spring at all. The pressure gage is now showing you the back pressure in the return system. Ideally it should be zero but that's nearly impossible. As long as it is under 3 psi the system will work reasonably well. With a 250 pump and -10 lines you should have less than 2 psi backpressure. If not, find the restrictions and remove them.
With this system the fuel pressure will never drop more than 2 psi at 1200 hp. With 750 hp the pressure will never drop more than 1 psi (the less back pressure in the return line, the less the pressure will drop under load; assuming you don't outrun the pump, which won't happen with a 250 pump).
A 250 pump will generally last about 50,000 miles if you filter the fuel and run a return regulator.
Re: 3/8" return line, how much will it support ? [Re: Quicktree] #34013
01/16/07 08:33 PM
01/16/07 08:33 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Well I have a Product Engineering pump and regulator set up and I've plumbed it as they recomend, I still can't see how a larger return line is effective if you want want's of fuel up there.
This is how PE want's you to plumb it
Re: 3/8" return line, how much will it support ? [Re: Bigcube] #34014
01/16/07 08:46 PM
01/16/07 08:46 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I want to run a 1/2" feed, 3/8" return, a bypass regulator, 1/2" in-tank pick up, stock tank and a Walbro GSL395 pump.
Here is the flow graph on the pump.
Re: 3/8" return line, how much will it support ? [Re: Bigcube] #34015
01/16/07 08:53 PM
01/16/07 08:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The best way is to check it like said above, hook it up, pull the adjuster and see where it's at with no load.
I agree with bigcube, you never need a bigger then supply line for return. Mine is -10 up, and -8 retun.
Re: 3/8" return line, how much will it support ? [Re: Bigcube] #34016
01/16/07 08:59 PM
01/16/07 08:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i'm sure there may be a difference between the way Product engin and mallory designed there bypass regulators. thats the difference.
on the mallory system, YES, they want you to run a line as large or larger than the feed line.
i have 1/2 out of fuel tank than -8 feed line and -8 return line and it works perfect. this is a mallory 140 pump and 4309( i think) bypass regulator.
also, per ROBMC's advice, my regulator is after the fuel log
Re: 3/8" return line, how much will it support ? [Re: FastmOp] #34017
01/16/07 09:10 PM
01/16/07 09:10 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Man! Why is it that when good info is posted(Quicktree) there is always one or more than one person who will dispute it. I'm sure you did your doctoral thesis on fluid dynamics. THE FACT is to PROPERLY plumb a return style system/regulator your return line must be AT LEAST the same size as the feed line and preferably 1 size larger. True return style regulators are back pressure sensitive and will not work correctly if there is any measurable backpressure on the return side. PERIOD. If doing it incorrectly works for you great but I think it is best to do it right up front to eliminate this area as a point of future problems. -Bob
Re: 3/8" return line, how much will it support ? [Re: BobR] #34018
01/16/07 09:32 PM
01/16/07 09:32 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
So, why do Fuel cell manufacturers make the cells w/ a return smaller than the supply? Not trying to , just wondering. I've seen a few of these posts, and wondered why the "Racing" fuel cells aren't plumbed the way you & others say they should be? I've also noticed that a lot of return style regulators have smaller -AN return ports than the supply port.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: 3/8" return line, how much will it support ? [Re: blairboy3] #34019
01/16/07 09:35 PM
01/16/07 09:35 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
for big pumps with bypass lines and dead head systems. i would assume thats the reason that BIGCUBES system is run with a smaller return because it actually runs a bypass and return line
Re: 3/8" return line, how much will it support ? [Re: BobR] #34020
01/16/07 09:43 PM
01/16/07 09:43 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My car must be magic then because wile it was flowing a huge volume through it before I started screwing in the regulator, the more I screw'd it in the less flow it had to the point that it was spraying out very hard but not very much volume at all. I use a Weldon regulator so it might have some built in voo-doo
Re: 3/8" return line, how much will it support ? [Re: FastmOp] #34021
01/16/07 11:46 PM
01/16/07 11:46 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Yes, I run a -8 bypass off the pump and also a return style regulator with a -8 return, perhaps that's why I dosn't have any issues There is nitrous "like" jet's in the high pressure side of the regulator and smaller jet's in the low pressure side, there is only just so much fuel that can flow though the return
Re: 3/8" return line, how much will it support ? [Re: Bigcube] #34022
01/17/07 12:00 AM
01/17/07 12:00 AM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
The size of the feed line is dependent on the horsepower the engine produces. The size of the return line depends on the size of the fuel pump, regardless of the hp or the size of the feed line. A larger pump requires a larger feed line to return the unused fuel back to the tank.
The following is from a magazine article I wrote about ten years ago:
"The minimum fuel line size (from the pump to the regulator) is dependent on the horsepower output of the engine (and/or Nitrous system) regardless of the size of the pump.
* Up to 250HP = 5/16" or -04 AN
* Up to 375HP = 3/8" or -06 AN
* Up to 550HP = 1/2" or -08 AN
* Up to 800HP = 5/8" or -10 AN
* Up to 1200HP = 3/4" or -12 AN
If you use a return-style regulator, you will also need a return line from the regulator back to the tank. The size of the return line is dependent on the size of the pump you are using, regardless of the engine's horsepower output. The return line must have limited or NO pressure in it. In many cases, the minimum return line size will match that of the supply line, but a larger return line is sometimes required if the pump is larger than necessary.
* Up to 45GPH = 5/16" or -04 AN
* Up to 90GPH = 3/8" or -06 AN
* Up to 200GPH = 1/2" or -08 AN
* Up to 360GPH = 5/8" or -10 AN
* up to 720GPH = 3/4"or -12 AN
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: 3/8" return line, how much will it support ? [Re: RobbMc] #34023
01/17/07 12:15 AM
01/17/07 12:15 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I want the basic system minus the pump to be 600hp capable. It just ticks me off because I would really like to be able to use the new 3/8" I already bought, but I think I am just going to have to bite the bullet and get a 1/2" return line done now.
I am going to get it all in SS from Inline tube, and Dante is going to get back to me tomorrow to see if Inline will discount the custom items. If so, 15% off of a $280 order is nothing to sneeze at.
Rob, with the fuel pump I will be using and the other dimensionally similar Walbro pumps available, in your personal opinion do you think that I should use the 3/8" or 1/2" return line for this specific instance ?
Re: 3/8" return line, how much will it support ? [Re: AlexP] #34024
01/17/07 02:25 AM
01/17/07 02:25 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
i run an aeromotive pump 10 an on the supply and 10 an on the return from the bypass regulator
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 3/8" return line, how much will it support ? [Re: RobbMc] #34025
01/17/07 08:03 AM
01/17/07 08:03 AM
Q
Quicktree Offline
Quicktree  Offline
Q
this should be saved
Re: 3/8" return line, how much will it support ? [Re: Quicktree] #34026
01/17/07 10:48 AM
01/17/07 10:48 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"this should be saved"
This arguement will come up again(like it has 1000 times before). There will still be folks who will dispute anything that may be different than what they have. -Bob
