74 dart rv2 AC question...
#340021
06/06/09 09:32 PM
06/06/09 09:32 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Evenin all. I put all the factory AC stuff back on the dart post BB retrofit. The front high side flange that bolts to the compressor is leaking oil. I put a new o-ring in but did not put a gasket on it as it didn't look as though it had one originally. Does this require an o-ring and a gasket? Russ:)
BigBlock 74 Swinger
Re: 74 dart rv2 AC question...
[Re: bb74swngr]
#340022
06/07/09 01:36 PM
06/07/09 01:36 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I don't get where is exactly leaking, but only gasket that compresor uses are on oil pan and heads... rest are O rings and one seal to crank
[Re: bb74swngr]
#340025
06/07/09 09:50 PM
06/07/09 09:50 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thanks Ignacio, Rich, and Doug. I will go with a thicker o-ring and if that doesn't work I will add the gasket that I just purchased. Thanks again everyone, we'll see what happens. Russ:)
BigBlock 74 Swinger
[Re: 70RR383]
#340026
06/08/09 12:23 AM
06/08/09 12:23 AM
NachoRT74
Valencia, España
If its the kind of oblong with two bolt flange,yes it takes a gasket and a o-ring.I reused mine and it was fine.Look close,my gasket was dark brown or black.It might be there,just wore ot.
ok, you mean the FRONT line flange ? still say is just an O ring.
Rear flange to the rear line ( with a pressure regulator valve inside compressor ) does use a gasket. is the 3rd gasket, so just 6 gaskets all around to compressor.
-2 at each head ( 4 in total ) -oil pan -rear line fitting flange
Just checked on Moparts parts catalog
[Re: bb74swngr]
#340028
06/08/09 04:02 PM
06/08/09 04:02 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The front discharge flange takes a gasket P/N 2008388, the rear suction flange uses a gasket P/N 1997446.
