Re: which water pump, 6blade or 8blade
[Re: RonaldV]
#33991
01/16/07 04:14 PM
01/16/07 04:14 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Originally the 8-vane pump was for non-A/C cars with the water pump driven at near (.95) engine speed, the 6-vane pumps are for A/C cars that have the pump/fan driven at 140% of engine speed. The extra fan speed on the A/C cars was to improve cooling at idle and could cause an 8-vane pump to cavitate at higher rpm's.
The Hemi also got overdrive pulleys in '69 and used the 6-vane pump from then on.
A non-A/C car with .95 pulley ratio should use the 8-vane pump.
[Re: John_Kunkel]
#33992
01/16/07 05:47 PM
01/16/07 05:47 PM
John is right on, as usual. As time has gone on, most of the later Mopars (small blocks) all went to the smaller pump and the overdriven (1.3-1.4) pulleys to help keep them cool at lower speeds with mechanical fans. If you have overheating at idle, it is the way to go.
As far as water flow through the engine goes, they are designed to flow the same, although I would expect the 8 blade to do a touch better at low rpm and the 6 blade at high rpm, by a small amount.
One thing to check for sure is that the pump is not using a GM or other aftermarket impeller in it, regardless of the # of blades. The impeller diameters are listed in some of the repair manuals, so it is fairly easy to check.
[Re: RonaldV]
#33995
01/21/07 11:27 AM
01/21/07 11:27 AM
Here are the original, factory, impeller sizes from my 1970 factory service manual. As I said earlier, you may find that the impellers being used are not Mopar sizes.
small block:
without air--4.38" dia.--8 blade--.95 drive ratio
with air--3.70" dia.--6 blade--1.30 drive ratio
big block:
without air--4.38 dia.--8 blade--.95 drive ratio
with air--3.50" dia.--6 blade--1.40 drive ratio
If your impellers vary from this, you will have to take a best guess at the right drive ratio.
