Re: Bought a strip/street project
[Re: sixpackgut]
#339601
06/06/09 02:19 PM
06/06/09 02:19 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
You will want to go small block and use the 73 and later disc brakes off A body. if you are not fimilar with these cars you must be committed to the build, they are not your regular old A body
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#339602
06/06/09 02:27 PM
06/06/09 02:27 PM
Posts: 382 Roseville MN
72swgnr
Roseville MN
Please explain
[Re: 72swgnr]
#339603
06/06/09 02:44 PM
06/06/09 02:44 PM
65signet
El Dorado Ca
The engine compartment is small on these cars not much room for headers, TTI makes them and you can get 73 and later A body disk brakes with the upper control arms and install the whole package
[Re: 72swgnr]
#339604
06/06/09 07:04 PM
06/06/09 07:04 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Hmm I wonder if my fathers (quickd100) 528 Hemi would fit in it
It won't go unless you bump me off . Headers are not a problem, I can make a set up to fit. Dad ![](/ubbthreads/images/graemlins/weld.gif)
[Re: roadrunnerreds]
#339608
06/06/09 09:05 PM
06/06/09 09:05 PM
65signet
El Dorado Ca
What radiator are running, and have you had it to the track, i putting one together myself
[Re: 72swgnr]
#339609
06/06/09 09:10 PM
06/06/09 09:10 PM
Posts: 484 PORT ALBERNI B.C. CANADA
71DemonRON
But BIG BLOCKS DO FIT, Schumacher has mounts !
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter 1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
